November 30, 2026, 08:54:11 PM
PlanePlotter 6.4.5.4 Released
Started by Anmer, March 17, 2017, 07:20:23 AM
Message from Bev at COAA:
PlanePlotter version 6.4.5.4 is on the web site today.
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download : http://www.coaa.co.uk/planeplotter6_4_5_4.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.5.3
Aircraft labels on the chart are displaced depending on the plotted symbol size to avoid the label being lost in the symbol.
New in version 6.4.5.4
Manual Mlats are performed peer-to-peer with no server involvement. This makes the procedure the same as the method used by Sector Master Users. As well as reducing the load on the server, this will avoid any synchronisation problems during busy periods.
There are still many new features on my list to add but since it is quite a while since I released a new version, please consider this an interim release.
Enjoy!
Bev
COAA
