November 30, 2026, 08:46:14 PM
PlanePlotter 6.4.5.5 Released
Started by Anmer, April 18, 2017, 11:10:50 AM
From Bev at COAA:
PlanePlotter version 6.4.5.5 is on the web site today.
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download : http://www.coaa.co.uk/planeplotter6_4_5_5.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.5.5
Conditional expression for OLE/CAM access
A new conditional expression has been added that controls the output of all OLE/COM interface calls that are non-specific regarding the airframe.
It does not control OLE/COM calls that request an aircraft by its specific identity or by its designated status. All other calls (eg. GetPlaneData) return only those aircraft that meet the condex condition if it is enabled.
Outlines overlaid on charts
There has long been an undocumented feature which allows outlines to be superimposed on charts. This now has its own option under the Options..Charts menu. The selection of which outlines to use, is controlled by the same selection procedure for outlines that are used on the normal outline display.
Automatic QNH retrieval
A long standing bug, in which the wrong QNH was retrieved when a map, as opposed to an outline, was displayed, has been fixed in this release.
Outline selection bug
A bug whereby closing the outline selection dialog without making any changes caused a crash, has been fixed in this release.
Enjoy!
Bev
COAA
e-mail this morning:
QuoteDear PlanePlotter User,
A PlanePlotter installation with registration number xxxxx, which was issued to you, has accessed the PlanePlotter sharing system with an old version of PlanePlotter (6.4.5.5).
Updates of PlanePlotter are free so please would you be sure to download the very latest version of the program from http://www.planeplotter.com/#download and install it over your old version.
Latest version on COAA site is 6.4.5.5.
Weird!
6.4.5.5 is definitely the latest version
http://www.coaa.co.uk/ppuserversions.php
Do you see your Share Code there Ian?
shakysen
Hi IanH. I got the same Email.  Anmer no share code
                                                           shaky
Quote from: shakysen on April 29, 2017, 02:27:00 PM
Anmer no share code
I was asking Ian if he saw his Share Code in the list on the link I posted.
On PP Yahoo Groups:
On 29/04/2017 10:16, Bev M Ewen-Smith bmes@... [planeplotter] wrote:
Version 6.4.5.5 is indeed the current version. I am not sure why the server sent out version warnings to those who are using the current version.
Please ignore the message. I will investigate the cause.
Bev
COAA
Yes my share code is in that list for 6.4.5.5.
But as has been posted since, seems it is an error by the server
