October 28, 2026, 06:25:20 AM
aviationpete
I recently downloaded the larger Countries DAT file with no issues. How ever the Air Tahiti Nui flight called for French_Overseas country flag instead of a France flag so i renamed a 40 X 20 BMP France flag as French_Overseas as enclosed.
Ospreyv22
Or put this one in for French_Overseas
terrywadeairbus
Would anyone please be able to supply me with the latest countries dat file for Taiwan, I'm currently using the one below, but some aircraft don't show the country flag, for example B-16735 B77W EVA hex 899039
Many Thanks
Terry
DaveReid
Quote from: terrywadeairbus on April 06, 2024, 09:40:26 AMWould anyone please be able to supply me with the latest countries dat file for Taiwan, I'm currently using the one below, but some aircraft don't show the country flag, for example B-16735 B77W EVA hex 899039
Many Thanks
Terry
That line corresponds to the range 899000-8993FF, so if it's not catching 899039 then I can only think that there's another line in your Countries.dat that's overriding it.
Quote from: DaveReid on April 07, 2024, 07:46:00 AMThat line corresponds to the range 899000-8993FF, so if it's not catching 899039 then I can only think that there's another line in your Countries.dat that's overriding it.
Forum member egnx has made a very useful tool to check the Countries.dat file.
You can download it from here
terrywadeairbus
Hi Anmer
I've downloaded the countries.dat tool that's very useful.
Is there any easy way of checking my countries.dat file to see what might be overriding this Taiwan hex?
Would a new install of the entire countries.dat file possibly sort it out, although that might be a bit drastic for the odd one or two aircraft that are missing country flags?
Terry
Quote from: terrywadeairbus on April 07, 2024, 10:23:01 AMIs there any easy way of checking my countries.dat file to see what might be overriding this Taiwan hex?
As it says "on the tin":
"By entering a hex ModeS code it will search a Countries.dat file and return:-
The binary representation of the queried Mode S
Every record where the queried Mode S matches the record's binary mask
The matching record that would be used as the displayed country is highlighted in yellow"
Give it a try!
Quote from: terrywadeairbus on April 07, 2024, 10:23:01 AMWould a new install of the entire countries.dat file possibly sort it out, although that might be a bit drastic for the odd one or two aircraft that are missing country flags?
Depends whether the replacement Countries.dat file has the relevant entries for Taiwan and doesn't "break" another hex range.
terrywadeairbus
Hi Anmer
In that case I think I'll just leave things alone and have the odd country flag missing
Thanks for you help and thanks egnx for the useful look up hex program
Terry
terrywadeairbus
Hi Anmer
I did use the tool for the Taiwan hex code and
it came back from an identical Taiwan dat file
I'm using
Did the hex code return just the one record for Taiwan?
DaveReid
My (very elderly) copy of Countries.dat only has a 16-digit mask, i.e. fewer trailing x's:
I don't think it should make any difference, but might be worth a try.
terrywadeairbus
Thanks David & Anmer
I'll have another look tomorrow to see what the look up returns
Terry
terrywadeairbus
This is the response from the hexcode check ?
   C:\Kinetics\BaseStation\Countries.dat
   Hex ModeS
   899039
   899039 = 100010011001000000111001
Terry
