November 30, 2026, 08:32:06 PM
PlanePlotter Version 6.4.5.6 Released
Started by Anmer, July 06, 2017, 01:35:31 PM
Message from Bev at COAA:
PlanePlotter version 6.4.5.6 is on the web site today.
http://www.coaa.co.uk/planeplotter6_4_5_6.exe
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download : http://www.coaa.co.uk/planeplotter6_4_5_6.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.5.6
Message rate window
Right/left clicking on the message rate window ("m"), in addition to stepping through the maximum scale options it also now includes a digital only display with no meter scale so the dialog is smaller.
Conditional expressions
If you use the number keys to switch between conditional expressions in the condex.txt file, the conditional expression now appears in the status bar when you press a number key.
A new noun "Olecom:" has been added to the options in condex.txt. It allows you to define a conditional expression to be applied to the data delivered by the OLE/COM functions.
Database refresh
A new OLE/COM function "RefreshDatabaseInfo()" retrieves any new data from the SQB database and updates the display accordingly. This is useful if you are editing the SQB externally to PlanePlotter, using a script and you want to see the result immediately.
MySky additions
The Sun and Moon symbols in MySky view are now fifty percent bigger to make them easier to distinguish.
In MySky view, the space bar now turns on and off the fiducial crosses on the display.
In MySky view, the zoom functions (+/- keys, toolbar buttons and mouse wheel) now zoom the MySky display. You can still drag the display horizontally but, as before, not vertically. Zooming in helps to distinguish cluttered plots near the horizon. Zooming out allows you to see higher elevations for aircraft approaching the overhead.
TCAS Alerts
Any TCAS alert will now unconditionally write to a file called "tcas-advisories.txt" with the details of the alert and the date and time. Since TCAS advisories are extremely rare, it has not been possible to test this feature.
Various
If you use a non-standard port setting for dump1090, that is now retained in the registry between sessions.
I hope you will enjoy these new features. Please let me know of any infelicities that you detect.
Bev
COAA
Slight update:
A slight wrinkle has come to light when using the number keys to
invoke a condex when the condex is very long.
Since in the new release the condex is now shown in the status bar, a
very long condex crashed PP if invoked in that way.
If you are affected by that, please download and install
once again as it now includes a limit on the condex length before
displaying it.
I have not incremented the release number as it is just a tiny
correction to the previous release.
Sorry for any inconvenience.
Bev
COAA
