May 01, 2024, 09:41:30 PM
WARNING - BaseStation not working with WIN10 3D update
Started by G4UMW, July 14, 2017, 01:23:37 PM
G4UMW
My PC (WIN10 64-bit) just updated itself with the latest so-called 3D version. Update appeared to go well but I am now unable to run BaseStation - I get the error message "The application was unable to start correctly (0xc000007b). Click OK to close the application."
You have been warned.
Rob
Rob/G4UMW
G4UMW
Not yet Mike. I'm playing with a few things but no progress to report as yet. I'll keep you informed.
Rob/G4UMW
Try installing BaseStation into a new directory and launch it from there.  Don't bother copying the sqb or any other configuration files.
Just to see if it launches OK.
G4UMW
Tried that already, still the same. Also checked the Microsoft .Net Framework and Visual C++ Redistributable but they're ok.
Rob/G4UMW
G4UMW
Performed a System File Check, all ok.
My brain hurts!!
Rob/G4UMW
G4UMW
Sorted. An updated version of the ftd2xx.dll file was required. If anyone else has the same problem, I'm using version 3.2.6.0 from here.
Rob
Rob/G4UMW
Thanks Rob.  I just talked to Chris Taylor at Moonraker and that's what he said it might be.
Cheers for the info.
Not had this problem yet but I guess it's only a matter of time.
Another good reason to keep visiting.
Keef.
Mature68
Wonder if you can give more info how to get basestation back up and running please.
Brian
Hi Brian
Can you describe what you're experiencing and are you running Win 10?
Mature68
Hi Anmer
Basestation was working upto wednesday ,when i start it up the logo page come on and load up the prog
then the screen just blank ,but the base logo is show on the botton task bar saying application error
click shut and get
Access violation at address 77E6DC9 in module ntdll.dll.Write of address 00000014.
Have try replacing the FTD2xx.dll  but didt work.
Hope this might help
Brian
Mature68
Do you have Teamviewer?  I can do a remote connect and take a look with you?
