September 20, 2026, 05:43:21 PM
actve display lite and the Beast
Started by hawg95, May 17, 2012, 04:54:42 PM
hawg95
i have been trying to get active display lite to work with the Beast but cant get it to run, it just goes into paused, anyone have any ideas please?
thanks
Have you got a Basestation type sqb file in use?
hawg95
Hi Anmer
yes i have a basestation  sqb file,  i have got a bit further, i have downloaded virtualradar run it and then downloaded the database writer plugin
and run that. then i went into tools options and pointed it at my basestation sqb file.
the prob now is it throws up a unhandled exception caught box that says SQLite error
no such column t0 operator flag code.
do you know which column number this should be, and if i can just add the column
to my basestation SQB file.will it cause a prob with planeplotter if i add a column? i dont want to use a new basestation SQB file, i want to use my own basestation sqb file, its taken me years to collect the info thats mine
thanks
Go to SBS-Resources website and download it.  Then use the Aircraft List Configurator to manage the aircraft columns.
hawg95
had a go at that, no luck, i then tried using the basestation sqb file that i downloaded from the SBS-Resources website still no luck. when i click start active display lite says basestation is not running and goes into paused
any ideas ?
AD is designed to work with the SBS-1/3 receivers and will be looking for suitable data on port 30003 of the PC running the Basestation software.  It will also be looking for the Basestation.sqb database.
I don't have a Beast so cannot test but have you got any data on port 30003?
