November 30, 2026, 08:24:08 PM
PlanePlotter Version 6.4.5.7 Released
Started by Anmer, July 27, 2017, 04:35:43 PM
Message from Bev at COAA:
PlanePlotter version 6.4.5.7 is on the web site today.
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download : http://www.coaa.co.uk/planeplotter6_4_5_7.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.5.7
Easier flightroute.sqb access
Jim has kindly cooperated in allowing me to implement a new feature in PlanePlotter to make it easy to download his regular flightroute.sqb updates.
The new option PlanePlotter...Options...Scripts...Fetch flight route database has two sub-options to select either the IATA codes (eg Heathrow = LHR) or the ICAO codes (eg Heathrow = EGLL) for the route points. The options are only enabled if processing is stopped. The transfer might take a few moments depending on your Internet speed. Note that if you are running more than one instance of PlanePlotter on the same machine, you must stop both of them before selecting this option because otherwise the transfer will fail. To display the route information on the chart, enable the "Rte" option in the Options..Chart..Options dialog.
Higher resolution outlines
"Bones" has very kindly allowed me to add a feature to PlanePlotter whereby his higher resolution outline files can be easily incorporated into the program. The familiar Outline button on the toolbar already has several different functions but this release adds an additional feature whereby holding down the right hand shift key on the keyboard while clicking on the Outline button on the toolbar, will download the "Bones" tile from the server for the area covering the centre of the current chart/outline display. It will then add that new outline file to the selection that you have made in Options..Chart..Outline..Select outline files. Note that if you have already enabled the global "General.out" file, there will be a duplication of coastline plots in the area covered by the selected tile. Be aware that downloading and enabling a large number of Bones' outlines, which are quite large, might make re-plotting the outlines take a long time. ! Like the lower resoluion outlines, the "Bones" outlines can be combined with the terrain option as described elsewhere and can be displayed in the orthomorphic projection.
Inmarsat input now "counts"
It was drawn to my attention that the message counter in the status bar did not increment when messages are received using the Jaero utility. That is now corrected in this release.
Additional ACARS position report formats
At John L's suggestion, I have added a number of additional position report formats to the decoders for ACARS and Inmarsat messages. Plane language reports via these two media use a bewildering number of different formats for position reports. The new ones added in this version should increase the amount of data that can be extracted from ACARS and Inmarsat reports.
Bug fix
There was a bug whereby if you selected Options..Chart..Outlines..Select or Options..Chart..GPX overlays..Select but did not make any changes to the selection, it defaulted to selecting all of them. If you have a very large number of such files in the Chart directory, as some do, this would mean that it took a very long time for the chart to refresh. This may explain some reports of PlanePlotter becoming unresponsive. That bug is fixed in this release.
Please let me know if there are any wrinkles that arise when using the new features.
Enjoy!
Bev
COAA
