November 30, 2026, 08:02:10 PM
PlanePlotter 6.4.5.8 Released
Started by Triple7, September 01, 2017, 03:01:39 PM
Since the boss is away - I'll do the honours:
From Bev:
PlanePlotter version 6.4.5.8 is on the web site today.
http://www.planeplotter.com#download http://www.planeplotter.com#download
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download : http://www.coaa.co.uk/planeplotter6_4_5_7.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.5.8
Colour selections
All colour selection (labels, backgrounds, etc,) are now completely general. Previously some of the colour options were selected from a short list of colours. This option should be backward compatible. Previous colours selected from the short list, should be mapped onto the more general colour coding scheme.
Automatic repainting
There is a new option "Options..Chart..Automatic repaint" which optionally repaints/replots the current outline or chart s few seconds after a drag or zoom of the chart or outline.
Note that replotting a chart requires an Internet connection. Note also that if replotting of a chart or outline takes a significant time, eg. if you have many .OUT files or many GPX overlays enabled, this might cause an unwelcome delay. In that case, it would be better to disable the option.
Squawk expansion
The yellow Info box can now display an expanded interpretation of the squawk code for those areas where squawk code allocation is systematic. To enable this feature you must provide a plain text file called squawkcodes.txt giving a list of squawk codes and their associated text descriptions appropriate to your area. You also need to turn on the option in Options..Chart..Info box.
An example file appropriate to the United Kingdom can be downloaded from www.coaa.co.uk/squawkcodes.txt. This example file illustrates the format for individual codes (XXXX<space>description) and for a range of codes (XXXX<dash>YYYY<space>description). The file should be saved into the PlanePlotter application directory.
Additional coordinate formats
This release includes a number of additional coordinate formats for Inmarsat messages that should increase the number of position reports retrieved by this method.
SBS log file naming
This release updates the log file name for SBS input where regular log file renaming is enabled.
Home location setup
Unfortunately, the Google Map server is no longer compatible with the mapping DLL that Nic Storey used in the home location setup in his installer package. As it was a show stopper for some users, this step has now been removed from the installer. Setting your home location on a new clean installation is now a separate step in PlanePlotter itself rather than in the installer. New installations over existing installations are unaffected.
Please let me know if there are any wrinkles that arise when using the new features.
Enjoy!
Bev
COAA
Then followed up with an addendum:
There are a couple of matters arising regarding the new release.
The automatic repainting of charts and outlines only occurs when PP
is processing data. It does not occur when the program is not processing.
The squawkcode.txt file is read once when the program first
starts. Accordingly, if you edit the file or create a new one, you
need to close PP and reopen it, not just stop and start it, for the
new data to be read into the program.
Bev
COAA
A note from me - the repainting option is actually found under Options>>Chart>>Auto refresh chart on move.
Thanks Tim.
Updated and running, I line the new squawk code feature, luckily I'm in the UK so the supplied file works for me.
Quote from: Keef on September 01, 2017, 04:49:26 PM
Updated and running, I like the new squawk code feature, luckily I'm in the UK so the supplied file works for me.
Me too. Didn't fancy compiling my own file  :)
