November 30, 2026, 07:42:03 PM
PlanePlotter 6.4.5.9 Released
Started by Triple7, September 06, 2017, 05:21:20 PM
Hot on the heals of 5.8 is 5.9
From Bev:
New in version 6.4.5.9
Squawk code expansion
The squawk code expansion introduced in 6.4.5.8 now appears for a designated aircraft and not just for a mouse-over aircraft. Edits to the squawkcodes.txt can now use either form of hyphen between the airport codes. The file must, however be ANSI coded not UTF-8.
Route code expansion
This release includes decodes for IATA and ICAO airport codes. Options..Charts..Info popup includes a new checkbox to display the text expansion of the IATA or ICAO airport codes, whichever version of the flightroutes database you are using. The expansion appears in the yellow info popup.
The two code files are compiled from diverse sources but are not warranted to be accurate so feel free to edit them to correct any errors or insert any omissions. Note that the files must be ANSI coded and not UTF-8.
Note that in both the squawk expansion and the destination expansion, if the field size is greater than the yellow box, it will expand to show the full text if the info box is on the left side of the screen but will not be completely displayed if the info box is on the right side.
Enjoy!
Bev
COAA
