November 30, 2026, 07:34:04 PM
Issue with Operator Logo's
Started by chrisellio, September 14, 2017, 07:47:22 AM
chrisellio
Thanks for doing the operator logos, I have a few logos that I believe are in my "operator logos" folder but do not appear on my PP display:- SXS, SLM, CND, CAI, NAX. I know with Country flags you sometimes have to edit the BSFlags note pad but don't know how to resolve this issue. Any help would be appreciated (in simple terms)
There are a couple of ways you can achieve what you want. The best way (I feel) is to use SQLite Expert Personal to inspect and edit your SQB file. Useful for all sorts of editing, not just the logos.
http://www.sqliteexpert.com/download.html
Scroll down to the section titled "SQLite Expert Personal 5.x " that's the free version. Install that with either the 64bit or 32bit version to suit your OS.
Before you do anything else, please - ALWAYS take a backup of your basestation.sqb file.
When you run the program it probably won't have an association to an SQB file. Click on Tools from the menu bar, then Options>>File associations. Click on the 'Add' box type ".sqb" no quotes, click on the selected box and OK that. You should then see that you have associated .sqb files with the program, so if you double click on an SQB file from file explorer, it will open this program. Not totally necessary but does avoid having to search for the file by clicking file open. Screen grabs 1-3 below.
You should then see a list of tables in the top left - screen grab 4. If it isn't highlighted, click on the "Aircraft" table and make sure the data tab is selected, you should see a spreadsheet looking screen with all of the data being displayed.
You can filter out everything apart from the entries you are interested in. So click on the "Customize" button - bottom right of the screen. In the "Filter Builder" box click on 'Press the button to add a new condition'. Then click on the green rowid link, scroll down to RegisteredOwners - select it. Then type in the name of the operator - sunexpress in this example for your SXS logos. Screen grab 5. If it works, you should see just the entries filtered on the owner.
Please take note, the next step will edit the live SQB file and there is no undo option, if you make a mistake it may corrupt your file. ALWAYS take a backup of your file before you start, yes I know I have already said that, but please do take a copy.
From memory the structure of the SQB file means the OperatorFlagCode is the last entry so you may need to scroll all the way to the right. I have re-ordered mine to suit my screen. If you don't see "SXS" in the "OperatorFlagCode" column, simply type it in and that will modify the file. Screen grab 6.
That's it really, just follow a similar approach for the other operators and ensure the correct code is showing in all the rows.
That's the way I recommend but there is also an alternative in PP itself. You do need to set things up to allow you to edit the SQB file first. From within PP, if you go to 'Options>>SQB hex database options>>SQB hex database file' ensure that that points to the correct file you are using in PP.
Then 'Options>>SQB hex database options>>Edits and auto regs update SQB hex code database' click it to select it, then repeat for the next line down in that menu structure 'Options>>SQB hex database options>>Edits and auto regs add to SQB hex code database' select it. That should set PP up to allow you to edit the SQB file. If you see an entry in the floating  aircraft window (a) simply CTRL+ Right click to bring up the Aircraft position report box and click on the Edit button you will see the edit box - screen grab PP_SQB edit. Enter the values you want and click on OK. That should do it from within PP.
I prefer the first method as from within PP, you need to have the aircraft on your display to be able to edit it. The first way allows you to check all of the entries regardless of whether they are being displayed on your PP screen or not.
Wow, that took a bit longer to sort out than I thought.  :o
E&OE as they say.
Just remember to backup your SQB file before you start.
Good luck,
