November 30, 2026, 07:23:58 PM
PlanePlotter Version 6.4.6.1 Released
Started by Anmer, September 18, 2017, 07:36:12 AM
Message from Bev at COAA:
PlanePlotter version 6.4.6.1 is on the web site today.
http://www.coaa.co.uk/planeplotter6_4_6_1.exe
I have released this a little sooner that I would have done but in the light of recent debate about receiver types, this version contains changes that might help users better to judge their receiver's multilateration performance.
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download :
http://www.coaa.co.uk/planeplotter6_4_6_1.zip
and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.6.1
Purge aircraft accelerator key
Alt-p now purges aircraft from the current displays. They will reappear as soon as new data is received off-air or by sharing.
Auto repaint improvement
If enabled, the automatic repainting of maps or outlines after dragging or zooming will now generally use the same style as the display being repainted. There are still some lacunas where the display came from a saved map within the Quick chart since the origin of the maps is not stored. Otherwise, the style (map type, selected outlines, terrain addition etc.) should remain the same after a repaint.
Identifiable hyperbolae
If you perform a manual Mlat and enable the display of the resulting curves that generate the fix, this version now shows any hyperbolae that were based on raw data from your own receiver, will be in yellow. All other hyperbolae remain in blue as before. The GS marker for your own location is also plotted in yellow (blue for other contributing GS). In addition the Mlat report dialog now shows the count of "own" hyperbolae in addition to the report of the total number of hyperbolae in the fix. I hope these three additions will help users to judge the performance of their own receiver when performing Mlats. If all the curves are blue, then your receiver has not made any contribution to the fix. If many curves are in yellow, then your own receiver is making a useful contribution to the fix.
Enjoy!
Bev
COAA
