November 26, 2026, 03:17:54 PM
SBS1eR and RasberryPi?
Started by tiga1050, October 27, 2017, 01:04:02 PM
tiga1050
Returning to virtual radar after some years away to discover there have been so many developments I wonder if I'll ever catch up?
Anyway, I have pretty much decided to put together a RasberryPi / Prostick setup as I would like to contribute a feed and wouldn't mind leaving a RPi running 24/7 whereas I'm not keen for my main computer to be on unattended.
I wondered if, as I still have an SBS1eR, whether it could feed the RPi or is the USB interface completely different?
Some advice would be very welcome.
I'm not aware of any software running on the RPi that can process data from your SBS-1eR.
If you get an RPi and Pro Stick, you use that set up to share data with numerous tracking services and run VRS and similar apps from it.
tiga1050
I expected that would be the case but didn't want to miss an opportunity due to my lack of knowledge.
I know I can use the SBS1eR and Base Station to feed data to Plane Plotter but I should like to feed data to another tracking service as well. I'll get the Prostick ordered.
Thanks for your help Anmer.
You can share data from PlanePlotter but you'd have to run the PC.  The joy of an RPi/DVB-T SDR (such as the Pro Stick) is you can let it run 24x7.
Nigel
If you'd still like to use Basestation to display the data from an RPi - Pro Stick setup that can be achieved quite simply using ModeSMixer2
Nigel
