November 30, 2026, 06:51:52 PM
Database
Started by goingaround, November 12, 2017, 05:57:13 PM
goingaround
I have just started with Plane plotter having used my Sbs1 er for a while. Reading through posted info about the .sqb database for PP, I see that it is up to the user to populate the data base with regards to aircraft registrations etc. Is it possible just to rename the data base I have compiled within Base station and use within PP?
You just need to tell PlanePlotter where your sqb file is located - Options->Directories.
But beware, unless you setup PlanePlotter correctly, you may find that your sqb file is updated by shared data.  Options->Sharing->Setup.
goingaround
Thanks for the reply. Will give it a go.
goingaround
Thanks Mike - sorted.
