September 23, 2026, 10:17:10 PM
Mexico City Airport Outline
Started by sdlangford, November 13, 2017, 09:28:34 PM
sdlangford
I am looking for an outline for Mexico City MMMX.
Active Display does not seem to have one to install.
Can anybody point me in the right direction please.
Thank you
Simon
Truetrack
Hi Simon
If there is nothing more detailed you might look into
http://www.rodbearden.com/RadarBox/Downloads.htm
It says for Radarbox but the outlines go for the SBS family as well
Klaus
sdlangford
Thank you, there was a MMMX outline but it does not show up on sbs.
Not sure why.
Sion
Have you saved the .out file in your Outlines folder and checked it in BaseStation?  Settings->Display Settings->Data Files.
Truetrack
And keep in mind what ever you add into the folder with a running Basestation to show immediately
may need to be reloaded, see Settings > Reload > click category
since the info about a file existence is read only once at startup of BS
Klaus
sdlangford
 think the MMMX outline has some errors within as its causing my SBS to crash and not showing up.
When I remove the OUT file SBS does not crash and no error message.
So no MMX airport outline that works yet.
Simon
There's an error in the out file which I've corrected.
I hope Rod doesn't mind me posting the corrected version here.
Tested with BaseStation.  No errors after the correction.
Truetrack
#7
After looking over the file for obvious fault usually point versa comma ect.
Found yes there is an error but easy to correct.
Open the file with a text editor
just in second line replace the ( by this { bracket type .
Then go the prescribed proc, it works I have tested it and it looks good
edit: Mike beat me
Klaus
sdlangford
Many thanks for this, now works fine and looks great.
Ready for my trip next week now.
Many many thanks.
Simon
