November 30, 2026, 06:27:54 PM
PlanePlotter Version 6.4.6.4 Released
Started by Anmer, December 03, 2017, 09:57:17 PM
Message from Bev:
PlanePlotter version 6.4.6.4 is on the web site today.
http://www.coaa.co.uk/planeplotter6_4_6_4.exe
This release improves the success rate for SMU Mlats in areas with few Ground Stations.
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download :
http://www.coaa.co.uk/planeplotter6_4_6_3.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files (SQB etc.) that are required to run the program.
New in version 6.4.6.4
SMU improvements
This version ensures that local raw data is available to all SMUs when performing Mlats. Previously not all SMU's were seeing their own data at each Mlat cycle. Tests have indicated that the SMU Mlat success rate in areas with few Ground Stations has improved spectacularly.
The limiting default clock rate difference between pairs of GS when processing Mlats has been relaxed. The algorithm calibrates out any clock rate differences so there was no need for such a strict check, which was causing some GS to be excluded unnecessarily from Mlat calculations.
Own LAN IP address
This release improves the retrieval of own LAN IP address in Help..Test networking, making it easier to set up port forwarding.
Trailing spaces
A problem with trailing spaces in flight numbers and flight routes, which affected the SetRouteByHex and SetRouteByReg OLE/COM functions, is resolved in this release.
Database checks
Since there is a perennial problem with users with missing or misplaced SQB databases, this version checks that the both SQBs are present and of non-zero length. It also checks that defined directories are not in the C:\Program files path to resolve another frequent problem.
I/O settings
This release explicitly checks that I/O settings are not configured such that PlanePlotter eats its own tail, leading to an eventual crash.
Enjoy!
Bev
COAA
