June 24, 2026, 02:00:58 PM
Active Display Lite and SBS3
Started by Mature68, May 28, 2012, 07:29:40 PM
Mature68
HI
Anyone using Active Display Lite with BS and SBS3 which is running update BS 171,after updating
active display lite will not run,was running on 127.0.0.1 :30003 have try other numbers but wont
connect to bs.
Any Comments Please
Brian
Hi Brian
I've just started AD Lite and it's telling me that Basestation is not Running.
I need to check tat I haven't got anything untoward at this end.  is this the message you're getting?
It's now working OK here.
I just remembered that AD Lite is looking for "Basestation.exe" as a running process and my one was called "Basestation171.exe".  Renamed it Basestation.exe and it's now OK.
Have you mapped AD Lite to your correct Basestation database folder?
Mature68
Getting the same message my is named Basestation.exe ,was wondering if the update as put it on diffent port and not 30003.
Brian
The required data should still be on port 30003 and you can test that using Telnet.  And it's working OK here.
In which folder location does your AD Lite expect to find Basestation?
Mature68
My Basestation folder is at C:\Tools\Kinetic\Basestation that is where it is pointing too,always been in that setting for day 1 when windows 7 came out.
Brian
Hi Brian
Have you changed anything since it last worked or started another application that may be grabbing the port data?
I can do a remote connect session to your PC and take a look with you?
Mature68
Hi Anmer
Thanks for the help have got it up and running was looking in the wrong places,
which i thought was the one lol.
Anyway thks
Brian
Thanks for the update.
So was it the Basestation path that was wrong?
Mature68
Yes when i install it i didt take the first option to find bs i took second and put it in myself lol
Brian
OK thanks.  At least it's now working.  :)
