November 23, 2026, 12:32:23 PM
SBS 1 Re-location-
Started by Graham Bell, March 05, 2018, 04:34:00 PM
Graham Bell
I am intending to bring my SBS box out of the loft  and locate it closer to my desk this will require renewal of the antenna cable which will need to be slightly longer.approximately 10/12 m.. Suggestions on cable type/pitfalls/suppliers will be most welcome.
Regards-
G.B.
Get yourself some low loss coaxial cable, such as LMR240 or equivalent, 6mm diameter.  You can consider Ecoflex or Westflex 10mm cable but it's hard to work.  LMR240 should be good for up to 15 metres.  Unless you have the tools, get the appropriate connectors added professionally.
https://en.wikipedia.org/wiki/Coaxial_cable
That link is for RG58 cable which isn't recommended for 1090MHz.
It has a max attenuation (signal loss) of 13.104 at 750 MHz per 100 feet, compared to 6.877 for LMR240.
Most get poor results with RG58 cable:
The traditional cables used for scanners etc. (RG-58) ar not suitable for these high frequencies, here you should use a good low loss coaxial cable. like Ecoflex-10, Aircom Premium or even Ecoflex-15.
http://www.wimo.com/gp1090-1090mhz-antenna_e.html#kabel1090
Graham Bell
Thank you all for your replies- Mike I am attracted to the LMR 240 you mention not least by the outside diameter, am I able to source this product in the UK?
Regards-
G.B.
I have no idea if LMR240 is available in the UK.  I'd contact one of the recognised suppliers and ask for an equivalent cable.
Maybe try Chris Taylor at Moonraker?  Or Henry Lake at Westlake?
The challenge is getting low-loss 6mm diameter cable with the connectors prefitted.
Graham Bell
Thank you for your reply Mike.
Regards-
G.B.
Came across this tonight, linked from Piaware web page:
https://www.lowflyingwales.co.uk/store/which-antenna-cable/
They sell an antenna but also lengths of cable.
https://www.lowflyingwales.co.uk/store/product-category/cables/
I would wait for  opinions on suitability.
Quote
The cable comparison tables look valid.
However, the cable on sale appears to be 10mm diameter with F-type connectors requiring adapters.
Bethsalem
I'm using 18 metres of Sky satellite RG6 cable and I'm getting 280nm regularly. I think a 20 metre pack plus connectors cost 15 quid  :)
Quote from: Bethsalem on March 19, 2018, 09:14:52 AM
What you don't know is what you're not seeing that you could with better cable.
As Donald Rumsfeld might say.
Truetrack
If the project is still ahead, here a few practical hints of pro and do not !
Even though quite some people use cables for entertainment apps TV/SAT ect. (75 Ohm)
and achieve their expectations and a few even good results,
In General Radio Comms 50 Ohm Impedance is adopted Standard,
and even some values are nominal
the Ant, Preamp, Cable, Receiver-inlet are designed for this standard.
Re Coax cable check wiki table > sort by attenuation .
Choose Lowest for a still practicable handling,
that is then about best at 10mm / 6mm, possibly up more rigid 15mm OD.
Observe Min bending Radius, Mfrs say Radius not less then 5 x OD.
Reason : Inner conductor may deform/slice into dielectric mat'l usually PF Foam.
Special attn: take care unreeling the Coax-coil not to produce any near-kinks,
just one temporary kink may spoil impedance and attenuation.
You will never know later.
To avoid additional attenuation use a minimum of connectors
So carefully choose between antsocket (+preamp?) to cable downlead
and (Bias Power injection) and flexible jumpercable to Receiver
either for a easy quick-connect BNC or the screw-on SMP.
Klaus
Graham Bell
My appreciation to you all for your ongoing inputs to this thread your suggestions and advice have been noted. I have to admit that this project has stalled somewhat of late mainly due to a succession of "Beasts from the East" has lessened my appetite to engage in outside activity! I hope to resume in the not to distant future,again thank you all for your continued interest.
Regards-
G.B.
