November 24, 2026, 07:19:03 PM
Is it possible to obtain IAS?
Started by AntRivas, March 15, 2018, 10:04:01 PM
AntRivas
Hi everyone
Recently I started a university project and I have to use the SBS-3 to obtain IAS. However I have been looking for a way to solve it but haven't found any related information.
Moreover I have heard that SBS-3 can receive Mode-S MRAR, what would be great because it contains the wind speed, but I don't know if it is possible.
Do you know some method to receive IAS through SBS-3?
Thank you so much
The SBS-3 is both a dedicated 1090 MHz Mode-S receiver and a tuneable Software Defined Radio (SDR).
1090 MHz "Raw data" is available from the BaseStation software over Ethernet on port 30006.  You will need a third party application to process this data.  See page 47 of the BaseStation Reference Manual.
Alternatively you may be able to tune the SDR to 1090 MHz and use third party applications to process the data as transmitted by the aircraft.
Or consider using a stand alone SDR receiver together with an RPi and relevant software.
AntRivas
Hi Anmer,
Thank you so much for your info, it is very useful.
Could you recommend a third party application to achieve this aim?
Thank you so much for your help
AntRivas
I'm not aware of any software that makes IAS available locally.
FR24 provides it, where available, on its website:
https://www.flightradar24.com/blog/understanding-extended-mode-s-data-in-flightradar24/
FlightAware says it's on its roadmap.
This post suggests IAS can be displayed in MMS.
https://discussions.flightaware.com/t/are-we-getting-full-ads-b-data/16468
Maybe post the same question in our topic board:
https://radarspotting.com/forum/index.php/board,56.0.html
AntRivas
Quote from: Anmer on March 17, 2018, 08:34:08 AM
That is great. Thank you so much again Anmer
Ranjeeh
Quote from: AntRivas on March 16, 2018, 08:55:45 PM
Quote from: Anmer on March 16, 2018, 06:50:30 PM
Is it only the IAS you need?
Yes, only IAS to obtain wind speed
Would TAS not be more useful? It will save you having to convert IAS against temp and pressure altitude. I'm assuming you are comparing airspeed to ground speed to get your wind data.
AntRivas
Quote from: Ranjeeh on March 19, 2018, 01:04:58 AM
Yes, you are right. I thought obtaining wind speed from IAS was easier, but I have to make several corrections, as you have said.
Regardless, I have read that Mode-S MRAR provides airspeed directly but I don't know how it could be obtained using SBS-3.
Thank you for your correction Ranjeeh.
