November 23, 2026, 12:13:39 PM
Basestation Aircraft List Problem
Started by IanH654, March 24, 2018, 04:31:27 PM
IanH654
Good afternoon,
I have recently installed Basestation on a Linx 1020, I am in the process of updating my settings and I am having a small issue with the Aircraft List.
The tabs with Flag, Registration, ICAO, Altitude etc all appear to be grouped up on top of each other in the top left of the Aircraft List screen. I cant seem to be able to get them to expand to go across the top of the screen or change the column width.
Can anyone assist at all ?
Hopefully its a quick and easy process.
Many thanks in advance to anyone who replies.
Ian H.
Hi Ian
You should be able to place the mouse cursor over the vertical line and drag the list edge to the left to make more of the columns appear.
Or you can edit the BaseStation.ini file.
AircraftListPanelContractedWidth=308
Making the width, example 308, whatever you want.
Save a copy of the ini file before attempting to edit.
IanH654
Thanks Anmer,
Sadly the mouse cursor over the vertical line doesn't work for some reason ...  The reason for my post unfortunately.
The '308' suggestion is a bit advanced for a non computer literate like myself sadly.
I will have a look in the morning and see how I get on.
Ian H
David Finch
Hi Ian
Have you tried the 'Aircraft List Configurator' software at  http://woodair.net/SBS/Utilities/Kinetic_Utilities5_Utils.htm.  If you scroll down the page you will see information on how it works.
It's a free download, easy to install, you have to tell it where your Basestation.ini file is.  It also creates a backup of your existing file when you save the new format.
Hope that helps.
DF
The Aircraft List Configurator is good for displaying columns and in what order.  However it doesn't handle the list width.
If Ian still has a problem, I can offer a remote connection to look at it together at a mutually agreed day and time.
David Finch
If you set each column width within the whole list using the configurator software and then save those settings to the .ini file, when you open the Basestation software it might just reflect those setting on the whole list.
Might be worth a try!!
DF
Quote from: David Finch on March 28, 2018, 04:06:58 PM
Good idea.  Unfortunately it doesn't work.  The line of code I posted doesn't get it's width from the sum of the columns.
I just tested it and using ALC to change the column widths has no affect on the total width of the aircraft list.
My origianl offer still stands.
acarslogger
Hi Ian,
Could you clarify your problem. You said
QuoteThe tabs with Flag, Registration, ICAO, Altitude etc all appear to be grouped up on top of each other in the top left of the Aircraft List screen...
Are you seeing any columns in the aircraft list?
If you expand the aircraft list using '<Open' do you then see any columns in the aircraft list?
Stuart
