November 30, 2026, 05:13:45 PM
Networking questions
Started by gcopter1, April 03, 2018, 08:03:39 PM
gcopter1
Quote from: IanH on April 04, 2018, 08:37:10 PM
I still don't understand from another thread how gcopter1 was able to see shared data previously, but not local data. If PlanePlotter is not setup where is that data coming from? When Anmer's instructions wre followed to set the port to 30005, local data was visible. Is the shared data also still visible?
I'm not going to contribute further until there is some clarity over what is being received and how. Ignoring questions about these things is personal choice but consequently I'm withdrawing from this thread.
Feeding Piaware MLAT data to PP is a big NO-NO.
Bye
A "NO-NO" how?
I'm only using their dongle, the ProStick, to get my ads-b signals. Processing that thru VRS and PP.
I'm not even sure I'm feeding MLAT data to PP as shown thru the failed tests.
If it helps, i can do a remote connect session with you at a mutually agreable time and see if we can sort this for you.
gcopter1
Anmer,
I'm off today from work but promised the wife I would drive here somewhere today.
Appreciate the offer, I'll be contacting you later.
I'm available everyday between 1PM and 4PM EST and am off Wednesday and Thursday.
gcopter1
Ok guys, finally managed to get it going.
I kept messing around with my router, the virtual server/port forwarding settings.
Last night while in bed with my iPad, researching the subject, I came across a link from PP to set up the router to enable port 9742.
One thing that kept coming back was to use the IP address of the computer running PP. Immediately I thought I was using the IP address of the Raspberry. Next day, I set out to find out I was correct all along, using the IP of the machine running PP, the MAC...?
Which brought me back to another question I had when I first started to work on this, I had to get the IP address of the machine running PP; the Windows machine which was running inside a virtual machine in MAC.
So, I had to get that address. Using the "Check own LAN/IP address" button in PP, I kept getting some weird ip address. By weird I mean it wasn't in the familiar 192.168.X.X range that my other devices running in the network, had. It was, 10.XXX.XX.X range, totally incompatible with all my other network devices.
Kept messing around with router settings up to the point where I ended up without internet.
Reset the router and when it came back up, went back to the virtual machine Windows settings and instead of using the "shared" connection with the Mac, I choose instead to use the bridged wi-fi connection.
I then opened up a cmd terminal on Windows and ran the ipconfig. This time I got an ip address similar to the others in my network, went back to the router admin page / firewall, and created the VS/Port forwarding rule to allow 9742 traffic with the new IP address.
SUCCESS!
Now, how do I go about requesting GS/MU status?
I know/seen, belong to, the PP Yahoo group, where people go to request this.
Before I do that, is there a format, protocol or other info I need before I put in the request?
Quote from: gcopter1 on April 27, 2018, 07:18:10 PM
Run the GS test:
Help>>Test networking>Test GS/MU Functions. You should be prompted with a "this installation is ready for GS approval" I can't remember the actual wording as my system has been approved for years. You should see something like the image attached. If so, post on the PP list or send Bev a direct email - info@coaa.pt and ask for GS/MU approval.
gcopter1
Yup, did that successfully.
Heading out to work now, going to leave PP running to eliminate the possibility that later on the day Mac, Windows and Parallels change my settings again.
Sometime after I did all of this, a message window popped up saying another device in my network was using the ip I've already had on my Mac. Gotten another IP address for it and made sure PP had the right IP as well. Ran the tests again and so far so good.
Thank you for the reply.
