November 30, 2026, 05:13:43 PM
Networking questions
Started by gcopter1, April 03, 2018, 08:03:39 PM
gcopter1
A bit about my setup first;
FlightAware Pro USB Stick
Raspberry Pi3
Running PlanePlotter inside a virtual machine with Windows 7.
Per PiAware, I'm feeding the data coming out of the stick and the RPi.
In PP, I can see my own traffic and the shared one. I've assigned them different colors in order for me to differentiate one from the other so, that right there, tells me so far I'm doing something right.
Out of curiosity, I've clicked on Help>Test Networking.
Raw data, master user, GS shows no and n/a. No surprise there as I have neither of those things.
Raw data out check;
Again, not a Master User but, the rest of the info worries me; I'm failing the UDP request.
Raw data in check;
The UDP message sent but no pop up report shows on PP.
LAN IP check;
Reveals an IP address that I don't have on PP I/O settings. The network name, is the one that Windows has given to my virtual machine.
G/S M/U test;
Shows my sharer ID and that I'm sharing this installation of PP on an IP address that's not on the I/O settings. On the I/O settings, UDP/IP Remote IP, it starts with 192, yet, the test shows I'm sharing on an IP that starts with 68.
NTP Test;
No association's ID returned.
AM I really sharing my data with PP?
One of my main reasons to use PP, in addition to enjoy it's flexibility, is to be able to see MLAT traffic.
By failing these tests, would that be detrimental to me seeing or contributing data to help with MLAT?
Do I need to become a MU or become a GS in order to fix this?
My inital thought was PANIC! You have to be careful to only send your own data to PlanePlotter, not the MLAT (shared) data.
So what are your settings in PP to receive your own traffic and the shared one - probably in  the Options/ModeS receiver settings. You are seeing both in PP so how do you set up to receive each?
If those are two separate settings, we can move on from there.
gcopter1
Using the IP address of the RPI. I'm away at work now but, if memory serves, that ip is in both the I/O and the  sharing setup?
I can provide some of the answers to your queries:
Quote from: gcopter1 on April 03, 2018, 08:03:39 PM
Correct, until your system is checked and you are given GS approval status, you won't see anything in those fields.
Quote
Raw data out check;
As IanH says if you post your settings and also what you have selected under I/O settings - Blue Spanner (wrench) 12th Icon from the left
Quote
Raw data in check;
Probably to do with a setting - same as above
Quote
LAN IP check;
I don't have any IP addressees in the I/O settings dialog box so not sure where you are seeing that.
Quote
G/S M/U test;
Correct the 192 is your local LAN IP address of the machine running PP and the 68 is your WAN IP address.
Quote
NTP Test;
See below for what I get when I run that test
Quote
Probably, but as IanH says you might also be sending MLAT returns from your FA receiver which would probably upset the PP MLat system.
Quote
One of my main reasons to use PP, in addition to enjoy it's flexibility, is to be able to see MLat traffic.
As above
Quote
We need a bit more information to answer that one
Quote
No problem!
I saw the post last night and decided I would reply in the morning when I had more time.
Others have since contributed.
I am sure you're sharing data but not set up for MLAT.  No port forwarding?
The test is showing your public IP address.  Not a local one.
I'm sure if you set up port forwarding as described in PP Help you'll pass the tests.
gcopter1
Screenshots.
Have you setup port 9742 forwarding in your router admin?
Extract from PP Help - seach for "9742" and read the Multilateration Tutorial
It follows from the above that each Ground Station must enable PlanePlotter to receive UDP/IP datagrams addressed to port 9742 and to send UDP/IP datagrams to any IP address on the Internet. This facility must be enabled in the user's firewall and, if necessary, in their router.
In addition to Anmer's suggestion about Port 9742, here are a few more thoughts
Your I/O screenshot might have more checked than you need. Mine's below. I have UDP/IP Data from net checked. You'll see that whilst I am using an SBS, I have nothing checked in the lower sections. I see you have an IP address for "remote control" under UDP/IP Output that will allow you to see the output of the main PP screen on a remote PC - in the help file under remote control these are referred to as "upstairs" and "downstairs" PC's. Do you need that? If that is the IP address of your RPi then that might end up with PP trying to feed the RPi - which won't work!
Maybe try with the minimum amount of check marks in the I/O setting dialog and go from there.
gcopter1
#8
Anmer,
I'm attempting to follow the tutorial. Including screenshots of my router settings.
The tutorial specifies to use 9742 for the Inbound port, the router has two boxes as to specify a range so I placed the 9742 value on both.
There are so many routers out there!
I usually find that Googling "Port Forwarding for xxxxx" will help, where "xxxxx" is your router make and model.
I still don't understand from another thread how gcopter1 was able to see shared data previously, but not local data. If PlanePlotter is not setup where is that data coming from? When Anmer's instructions wre followed to set the port to 30005, local data was visible. Is the shared data also still visible?
I'm not going to contribute further until there is some clarity over what is being received and how. Ignoring questions about these things is personal choice but consequently I'm withdrawing from this thread.
Feeding Piaware MLAT data to PP is a big NO-NO.
Bye
gcopter1
Another thing I found that might bear some relevance, in Windows 7, I looked into the Firewall settings.
PlanePlotter is there, it has Inbound and Outbound rules.
On the inbound rules, there's two rules for PP, UDP and TCP. None specify port 9742 but do allow any port to be used.
On the outbound rules, there's only one for PP and the rule allows for both UDP/TCP and any port.
Regarding the port forwarding for my router, yes, seen the YouTube video. Have no problem accessing the router, I just don't know what values to use where except for 9742. If I use it for both in and out fields, there's no difference in PP.
Currently I see both local and shared. I'm basing this on the fact that on my screen, I've assigned different colors for each. I even went as far as inverting these colors to make sure I was in fact seeing my own and the shared data.
Where I'm hitting the wall is when performing the networking tests and port forwarding.
I've read the PP tutorial where it says to make sure the router is forwarding data to port 9742.
Trouble for me is that, wether I use virtual server/port forwarding or port triggering in my router, there's no change in the status of the tests.
My router asks a port number for in and out. I already know PP wants 9742, what do I use on the other field?
gcopter1
Correction, my router dialog box for Virtual Server/Port Forwarding has inbound port and local port, not outbound as I previously said.
So, the PP Multilateration tutorial specifies that I use 9742 to receive (inbound), so what values is needed to assign to the local port?
gcopter1
They are hence my frustration.
As it is right now, I can see my traffic and the ones by sharers .
I'd like to solve this so that I can be GS/MU and see MLAT traffic.
Sigh.
Oh, BTW, thanks to all who have contributed to the thread.
