September 22, 2026, 02:32:48 PM
sbs patch lead
Started by n1tr0mad, May 20, 2018, 09:51:19 PM
n1tr0mad
Hi All
anyone know where a buy a lead to go from SBS to male type ?
i either find 10 meters plus leads or 75ohms leads could someone point me in right direction for 50omhs sma male to n type male ~1meter ?
thanks
Gav
Do you need 75 Ohm? Surely it should be 50 Ohm for 1090 MHz?
What are you connecting?  From, what to what?
n1tr0mad
#2
Quote from: Anmer on May 21, 2018, 07:54:56 AM
Quote from: n1tr0mad on May 20, 2018, 09:51:19 PM
Hi All
thanks
Gav
i was saying all i can find is 75omhs short leads but i want 50omhs patch lead  ;)
thanks
Gavin
it also to connect the sbs 3 and flightaware stick to female n type connectors from aerials
Quote from: n1tr0mad on May 21, 2018, 08:41:29 AM
Ah, gottit.  Sorry I misunderstood.
Where is the antenna located in relation to the SBS?  It sounds like you want to connect the SBS directly to the antenna?  Most antenna coax comes with an N-type for the antenna and SMA for the receiver.  I use short patch leads to connect receivers to the Mini-Circuits splitter.  They're 50cm long, bought off ebay.
There was no impedance quoted and for that length I don't think it matters.
n1tr0mad
#4
current way is aerial---mast amp---earth box---indoor connection block-----bias-t-----receiver
this is the "earth box" in the box is an diamond sp1000 and sp3000 lightning arrestors with a claimed insertion lost of less than 0.3db.
box and fittings are ip67 rated so it seals the cable access though my wall
the rg58u is an now unused power feed to scanner amp then the RFC400 is airband then 1090.
the plug style on my indoor connection blocks are n type females
so i am looking to take out the now un-used bias-t that is currently "BNC to sma" and connect directly to the indoor block thats needs "male n type to sma"
IE: aerial----earth box---indoor connection block-----receiver.
i am using right now a n type to BNC adapter but in VRS my receiver stats have gone werid thinking it a bad adapter
going though bias-t
using BNC adapter
gav
Quote from: n1tr0mad on May 21, 2018, 09:45:04 AM
So you need a <1 metre patch lead with N-type male one end and male SMA the other?
n1tr0mad
G4UMW
Rob/G4UMW
