November 30, 2026, 04:23:41 PM
...another what is this?
Started by gcopter1, June 05, 2018, 09:53:24 AM
gcopter1
Never seen this before.
I have alert zones set for any aircraft about to enter the airspace around my location. As I'm browsing the net, the alert popped out over my browser. 0 distance from me!
gcopter1
Nobody has an explanation?
I'm curious as to the source. Test 1234, 0 distance from me squawking 7777, no registration, I mean, who, what could be doing this? What purpose?
I don't use PlanePlotter but how come an alert for an aircraft within a specified area was triggered for a message without any positional data?
Quote from: gcopter1 on June 05, 2018, 09:53:24 AM
Found this piece of info for you.
Airman's Information Manual AIM 4-1-20 e.2 says, "Under no circumstances should a pilot of a civil aircraft operate the transponder on Code 7777. This code is reserved for military interceptor operations." (AIM 2016 edition, seems to be the latest edition as of 2017 Sep)
Truetrack
Not using PP either. Using BS-SQB-Reporter
Presumably be one of Ground Station Tests each with Flight ID Test1234
In the past noted for various European major hubs like EHAM, EDDF, LSZH,
each often with one of 3 to 4 diff ModeS Codes of their country allocation.
Most have not one other info in BS, but a few just with a same Alt (First+Last)
BTW airframes.org says ADF994 is by Newark Ground .
Squawk 7777 is used for intercept ident ( military use )
see somewhere in General section in DOD-Flips.
No idea how that routing local EDDH-EDDH was sampled.
Klaus
gcopter1
