November 30, 2026, 04:35:44 PM
PP New Search Facility
Started by Triple7, June 13, 2018, 04:42:28 PM
From Bev,
I have set up a new feature that allows users to search for a specific aircraft or group of aircraft on a specific date. It only works if you are running a registered copy of PlanePlotter.
You can specify an aircraft to search for using the registration, hex code or flight number. If you specify none of those, it will search for all aircraft.
You can search over any chosen (UTC) time range on any chosen (recent) date. You can limit the search to a specific geographical area and you can specify a range of altitudes for the results.
So, to search for a specific flight, just specify the date and the flight number (callsign). Leave the rest at the defaults.
To search for a specific aircraft, just specify the date and the hex code or the registration and leave the rest at the defaults.
To search for all aircraft in a particular zone, specify the date, time and the geographical coordinates and the altitude range of interest and leave the aircraft identity blank.
You can use wildcards in the aircraft identifiers to restrict the aircraft types, country or company that are returned.
You can select output as plain text, a GPX file for display in PlanePlotter, a replayable log file that you can play in PlanePlotter, or a KML file to display on GoogleEarth.
The server normally keeps the data until the end of each month and it is then archived so do not expect to be able to search for data from before the start of each month.
To avoid overloading the server, there is a limit of 1000 records output from the search so don't look for all aircraft over a wide area at all times or the result will disappoint.
Please use this feature sparingly as it does occupy the server. If there is a load problem, we may have to disable the script.
If you have read this far, you deserve to know the URL : http://www.coaa.co.uk/retrievepphistory.htm
Bev
COAA
Tested and it works well if you enter in a lat and long "rectangle"
