September 23, 2026, 04:06:14 PM
MLAT from flightaware
Started by n1tr0mad, June 20, 2018, 04:51:35 PM
n1tr0mad
i have both MLAT and adsb fed from a flightaware pro stick plus filter using ports
30105 for MLAT
30005 for adsb
what i seeing more and more is MLAT aircraft will show speed,heading distance etc but don't show on the map or have "show on map" on aircraft list
i know its not gone out of range as the message count is still going up on a few  i can be tracking for over 30mins without it showing on map
all settings are default part from normal changing layout etc
any ideas ??
cheers
Nitro
reeza
Having the same issue, I can't seem to work it out. Have you had any luck fixing it? Cheers.
Suggest that you ask on the FlightAware forum - they should be able to identify any problems with your setup.
Quote from: reeza on November 14, 2020, 09:08:28 PM
Can you describe your setup and exactly what you're experiencing?  Screenshots can help.
n1tr0mad didn't provide further information when asked.
