November 25, 2026, 10:12:25 AM
Help with networking SBS-1er
flyoverfred
Hi guys,
I really need your help. A friend and I are trying to get my sbs 1er to work over the network, we get a reply when pinging but it simply doesn't show up on the software and the light fails to illuminate to says it's on the ethernet. The box is plugged into the modem and my pc is elsewhere in the house. This is the bit we don't understand - can anyone help decipher why it keeps failing here or what this even means ?
2022/04/14 : 15:56:57.990 : Initialising data message socket
2022/04/14 : 15:56:57.996 : Opening data message socket on 30003
2022/04/14 : 15:56:58.012 : Initialising raw data socket
2022/04/14 : 15:56:58.019 : Opening raw data socket on 30006
2022/04/14 : 15:56:58.034 : Opening ACARS data socket on 30008
2022/04/14 : 15:56:58.052 : Initialising raw audio socket
2022/04/14 : 15:56:58.059 : Opening RTSP server socket on 554
2022/04/14 : 15:56:58.073 : Opening raw audio server socket on 30005
2022/04/14 : 15:56:58.594 : Main Socket Connected
2022/04/14 : 15:56:59.084 : Locked for 00:00:05
2022/04/14 : 15:57:02.845 : Sending login string
2022/04/14 : 15:57:27.917 : Main Socket Connecting on 192.168.0.170:10001
2022/04/14 : 15:57:27.935 : Main Socket Connected
2022/04/14 : 15:57:32.918 : Sending login string
2022/04/14 : 15:57:57.961 : Main Socket Connecting on 192.168.0.170:10001
2022/04/14 : 15:57:57.988 : Main Socket Connected
2022/04/14 : 15:58:02.964 : Sending login string
The ping is using an SBS-1eR IP and port address of:
192.168.0.1701:10001
The default IP address (hard coded) is 192.168.1.170.
Has the SBS-1eR had it's IP address changed?
These Guides may help:
Networking the SBS-1
Changing the SBS-1 IP Address
Please post again if you still need help.
flyoverfred
Hi Anmer,
yes the sbs/Lnatronix xport has had its IP changed to match my network. We can ping it and get the response back with no loss but it simply refuses to connect.
The SBS has worked flawlessly for many years on USB but I want to move the sbs to the loft where I have access to the network via cable. Connecting via both the router and a switch have been tried and both ping ok but with the same response. It seems to stall at the "login string". We have also reset to default (192.168.1.170 and subnet of 255.255.0.0) and get the same response.
Really not sure where I go from here ? Is it worth having a go with your reset program if you still have it ?
Faramir
The SBS-1 is connected via the router to the PC that is also connected to that same router I believe. Perhaps some firewall/portfilter issue? If you got a cross-over network cable you could try to connect the SBS-1 via Ethernet directly to the PC.
The login listing you posted, is that from Basestation?
I assume in Basestation Settings -> Data Settings you've selected "Use Network"?
And what do you have in Settings -> Hardware Settings -> Network?
DaveReid
+1 for the advice to try connecting directly to the PC - you can get a crossover cable for a couple of quid on eBay, if you don't already have one.
Dave
flyoverfred
Hi all,
Anmer - the login string response is from the basestation debug window. I will get a crossover cable that you all suggested and report back - appreciate everyone's replies
flyoverfred
so my friend logged back into my pc and mucked around with some settings on the Lantronix page and somehow got it to work. In all honesty, he told me what he did but it went right over my head but he got it all working on 192.168.0.1701:10001
Good to hear it's all fixed.
Maybe ask your friend to write a short note explaining what he did which you can copy and paste here?
