November 25, 2026, 10:12:23 AM
Help with networking SBS-1er
egnx
Thanks, I see your email and will act on it when I get home later.
Should the reboot of the SBS-1er be obvious after the settings have been applied ? Having done that a few times now, I have never noticed anything happening after the apply setting progress bar has finished.
The "Lantronix Device Installer" software that I have been using (to just look at the config after making the changes) does allow you to change the ip address but it mentions that it should not be done via a router or Gateway. Does this apply to the reset util you provided ? If that is the case then I need to get a cross over cable before I can connect direct to the SBS-1er from my pc.
I haven't used the utility for years but I'm pretty sure it will work using patch/straight Ethernet cable connected to the router or PC.
The SBS shouldn't need a reboot.
The email has step-by-step instructions which have definitely worked for others recently.
egnx
I used the EM reset utility, followed all the instructions and bingo all is now working!!
Many thanks for your help with this, much appreciated.
Kelvin
Fantastic.  I'm really pleased you got this resolved.
Maxie39
Hello Anmer/other users,
I am fairly new to the SBS-1eR and new on this forum. But I read this topic and it seems that I also have this problem. I can connect the SBS-1eR via USB to my basestation perfectly, but when I want to connect it with ethernet it does not work. The IP address is 192.168.1.170 and Port 10001.
I can ping the network. The leds in front show only a red one on the left, and three blue leds on the right. No ethernet led (yellow) turns on. When using the USB, the led for USB also turns on and the connection turns on.
Is it also possible that after a reset of the EM it works? What do you guys think?
When you ping 192.168.1.170 what result do you get?
Resetting the Lantronix device may help.
Maxie39
When I ping 192.168.1.170 I just get the packets received/sent. In windows all 4 packets received and sent well. In Linux the ping just goes on and on.
Resetting the device? By just turning it OFF/ON again? Or is there another way?
How familiar are you with the Basestation software?
When you connect using Ethernet, are you changing the data source in BaseStation?
Settings -> Data Source -> Use Network
Maxie39
Hello Anmer, thank you for the quick reqply.
yes I am aware of that setting, when I set it to Use Network I also restart the Basestation software. I read that somewhere in the ReferenceManual.
Also, under Hardware Settings > Network   I have filled in 192.168.1.170  Port 10001. I can also login to the Lantronix XPort Device Server configuration Manager via the IP address through my web browser. I also tried to do a 'Apply Default' but no luck.
Any ideas?
Thanks again.
There's no need to restart the BaseStation app when you change the data source.
Is the Ethernet cable from the SBS-1eR connected to a router/access point or your PC?
Maxie39
#25
I could've also added that.
I am using a Windows 10 laptop, connected directly into the ethernet port. I have made an address on the port 192.168.1.10. In wireshark I can also see that it is connecting (ACK). But somehow basestation is not connecting with it..
EDIT: See attached screenshot of the wireshark connection.
Sorry about all the questions.
Connecting an Ethernet device directly to a PC usually requires a cross-over cable.
https://en.wikipedia.org/wiki/Ethernet_crossover_cable
The SBS-1eR possibly cannot handle the use of a non-crossover cable.  I can't be sure but I rememeber this was an issue when the SBS ethernet option was released.
Can you connect the SBS-1eR to a router or network access point and try again?
Maxie39
Aah okay. I can yes, I will try and come back to you!
Please let me know how you get on.
Maxie39
I connected a switch but it still doesn't seem to work. I connected it as folllows|:
PC <NetworkCable> switch <NetworkCable> SBS-1eR
