November 29, 2026, 02:20:53 AM
PlanePlotter 6.4.7.4 Released
Started by Triple7, October 18, 2018, 12:46:55 PM
From Bev
PlanePlotter version 6.4.7.4 is on the web site today.
---Usual boilerplate---
New in version 6.4.7.4
View..Polar diagram
This new feature records and displays the area coverage of your receiver/antenna.
The maximum reception range and the lowest reception angle above the horizon are recorded for each degree of azimuth.
If you select View..Polar diagram..Plot max range, the envelope of the most distant reception is overlaid on the current map or outline.
If certain azimuths have no data, for example if no aircraft fly in certain directions from you, then the curve will interpolate from adjacent azimuths.  This is of course, an approximation.
If you select View..Polar diagram..Plot range by altitude, then a series of curves are plotted calculated from the observed lowest height above the horizon for each azimuth.
Note that these are not measured, they are inferred from the lowest reception angle and calculated from the chosen altitude and the curvature of the Earth.
The calculation takes no account of your antenna height.  The assumption is that the lowest observable angle in each direction is the determinant for the range at each altitude.
By default there are five curves plotted for 5000', 10000', 20000', 30000' and 40000'.  These curves are dashed and are thinner than the curve for maximum observed range.
Note that the curve for 40000' will usually be beyond the maximum range actually observed unless there happened to be an aircraft at FL400 at that range.  This is to be expected.
View..Polar diagram..Setup allows you to choose the colours of the various curves, the altitudes to which the curves correspond and how many of those curves are to be plotted, up to a maximum of five.
Enjoy!
Bev
COAA
Bill - please note!  ;D
