November 28, 2026, 01:12:57 AM
PlanePlotter 6.4.7.7 Released
Started by Triple7, November 09, 2018, 03:17:35 PM
From Bev:
New in version 6.4.7.7
http://www.planeplotter.com/#download
Google Maps (for a fee)
PlanePlotter users will be aware that recently, both the Google Maps and OpenStreetMap servers used by PlanePlotter have not been delivering the expected results.
The Google Maps server now charges us for each map download and the OpenStreetMaps server has simply stopped working.   I looked at putting an OpenStreetMap server on our own server but the storage and processing demands were excessive.
This lastest version of PlanePlotter allows you to buy credits for map downloads from the Google Maps server. We regret having to pass on this cost but with so many users, some of whom download charts very frequently, we cannot meet the cost ourselves on top of the cost of running the sharing server.
There is no compulsion to buy map credits; if you only use outlines, you will be unaffected by the change in Google Maps policy.  If you only download maps very occasionally, then you will be unaffected as we have credited all current users with a small number of free downloads.
If your map credits are exhausted and you click the Map button, you will see a message in PlanePlotter suggesting the following:
You can reload a previously downloaded chart with File..Open chart, or by pressing Ctrl-O.
You can see an index of existing charts with View..Chart index, and then double clicking on the title of a chart.
You can press F7 to load the largest downloaded map covering the current map centre. This may take time.
You can press the button below to buy 1000 more map download credits for €10 plus taxes.
And then there is a button on the last line of the dialog box.
All but the last solution, cost you nothing.  Only the Map Credits cost anything.  If you do buy 1000 download credits, I expect that will last most normal users a very, very long time.
Caveats.
Because of the way it works, the map download credit is specific to one installation only of PlanePlotter.  If you regularly use more than one installation, then you can choose to divide the map credits equally between all the current installations registered to you.  I intend to automate this option but I have not yet done so.  Until then, if it is urgent, ask me and I will do it by hand - provided there are not too many requests.
Note that a map credit is used up each time you download a new map; that includes each time you press the Map button or you press the Test button in the Home Location dialog.
I am sorry that this has been necessary and if I find a comparable free map server I will add it as an option under the Map button.
At least there is now a way to get fresh maps in PlanePlotter.
Bev
COAA
A post on the PP list advised that the OpenStreetMap server is working again - so you may or may not require this update.
