November 28, 2026, 12:35:13 AM
PlanePlotter 6.4.8.1 Released
Started by Anmer, January 28, 2019, 08:30:03 AM
Message from Bev at COAA:
PlanePlotter version 6.4.8.1 is on the web site today.
---Usual boilerplate---
New in version 6.4.8.1
Automatic air band tuning of SDR#
This release adds a preliminary version of a remote frequency control option for SDR# to allow automatic tuning of ATC channels based on the location and altitude of the aircraft that you designate by double clicking on its symbol.
PlanePlotter has, for a long time, supported tuning the SBS-3 SDR to appropriate VHF ATC frequencies based on the location and altitude of the designated aircraft.  This release does something similar for the SDR#.  You will need a dongle and SDR# to be used as the VHF air band receiver which this feature will control.  This is obviously a much more affordable solution than the SBS-3, although not quite as useful, as I will explain.
To use the feature, you first need to install an add-on for SDR# called Net Remote, which is obtainable here:
http://eartoearoak.com/software/sdrsharp-net-remote
With that add-on installed, PP will use a user-supplied file called 'sectorfreqs.txt' that defines the frequencies associated with each geographic area and altitude sector.  This feature uses the same definition file format that was used by PlanePlotter to tune the SDR in the SBS-3.  The format of the file is described in detail in the Help file but to make it easy, you can create or add to the file using 'PlanePlotter..Options..ATC sector frequencies (near the bottom of the pull-down)..Add a new ATC sector frequency'.  There is, of course, a tacit assumption that you know your local ATC frequencies and the areas and altitudes to which they refer.
As there is only one tuner in SDR#+dongle, as opposed to the four in the SBS-3, it is only possible to allocate one frequency to each sector.  In view of that, when you create the 'sectorfreqs.txt' you should try to divide up the airspace into non-overlapping boxes to get the best chance of hitting the relevant frequency.
PlanePlotter will track the designated aircraft and re-tune SDR# to the frequency you have defined for the current location and altitude.  In practice, aircraft will often change frequency before reaching the precise sector boundaries so if you are following an aircraft, you may develop the technique of helping the tracking by designating an aircraft that is already in the next sector, so that SDR# will go to that channel before the aircraft of interest would have triggered that transfer by crossing the boundary.
The SBS-3 implementation does not have that problem, because it has four tuners and so can be receiving channels appropriate to both adjacent sectors by defining their areas to overlap.  That option is not available for this feature using SDR# with its single tuner.
You need to turn on the feature using 'Options..Airband receiver tuning (right at the bottom of the pulldown)..SDR# tuning enable' before you start PP processing.  The button is disabled when PP is processing.  Note that I took the decision not to preserve the state of this option between sessions so you need to turn it on explicity at the start of each session.  I did that because if SDR# is not running, with the option enabled, PP cannot connect to SDR# and so cannot start processing and it might not be obvious why.
The utility of this feature will depend very much on the simplicity or otherwise of your local ATC sector structure. I find it useful!
Inmarsat CPDLC decodes - improvement
This version expands the utility of CPDLC decodes from Inmarsat in determining the course and speed from the next waypoint in a CPDLC message where the waypoint is specified by name rather than by latitude and longitude.  This means that the 'chocolate' plots will more commonly have an oriented aircraft symbol (derived from the next waypoint and estimate) rather than the default triangle, which the previous release showed under those circumstances.  This feature will only be relevant to 'big dish' users but when they have updated, it will increase the information available to all PlanePlotter users.
Enjoy!
Bev
COAA
From Bev,
Enjoy!
Bev
COAA
