November 28, 2026, 12:18:48 AM
Help TellMe Software Alert Line
Started by BENI, February 18, 2019, 04:49:55 PM
BENI
Hey
I ask for help to create a warning line for the TellMe Program.
I need to put in that line, to say that those types of planes with Altitude between 22,000 feet and 7,000 feet, give me that alert to my mail.
I hope I do not ask much
Thank you so much
Do you have the Tellme PlanePlotter "Add-on" installed and working?  Have you been able to set any basic alerts?
I don't use Tellme but it doesn't look too user friendly.
Have you asked on The PlanePlotter Yahoo Group?
Ah TellMe - that takes me back. I haven't used it for years, but a quick review suggests a line something like this in your TM-Alert.txt file might work:
5;;;M;(>7000|<22000)
You will need to ensure you have set the ini file up with your email details as per the TellMe.txt help file. You will also need to set the .ini file with the parameters you want included in the email. The example in the ini file may be sufficient EmailData = 0,1,2,11,12,15,16 so that needs to be entered to the right of the = sign in the section under the heading 'Data to include in Alert Email notification message:'
This is a guess on my part but it might be worth trying to see what results you get. It is, as Anmer implies, a bit tricky to set up but I guess if you want the email alerts it is probably worth persevering
E&OE as they say
BENI
thank you for trying to help, but unfortunately it does not work, I think the signs of (<and>) are the problems, I'll keep trying.
In any case, any help will always be welcome.
I also use the VirtualRadar, I have tried to make the PlaneAlerter 2.0.6 work, I like it a lot, but when I receive the alert I get a blue map, where the position is not seen, I think it's an API problem, although I understand that the V .2.0.6 already comes with API, is what I understand, just like I have to buy that API, I do not know.
If I can not find a solution here, I'll send a message to the PlaneAlerter forum in case it's my problem.
Thank you very much for your help
regards
