November 10, 2026, 10:39:32 PM
Look up error message in Flight Display 7-
Started by Graham Bell, March 09, 2019, 02:47:04 PM
Graham Bell
I appreciate that FD is a bit long in the tooth and has been unsupported for some time  but I still use it primarily for the Alert function but recently it self closes on a regular and frequent basis and flags up this error message:-
"There have been more than 10 internet look ups.Press start  button to resume look ups."
Can anybody enlighten me as to what this means and are there any known fixes?
Regards-
G.B.
Sounds like one of your lookups is failing, either because the script is no longer valid or the remote service isn't available.
What lookups do you have?
Graham Bell
Thanks Mike info as follows in order:-
1---FRL Service
2---Libhomer
3---Flight Aware
4---Flight Stats
5---Flyte Com
Regards-
G.B.
Thanks Graham.
I think there's an FD error log that notes which service is failing.  Check the FD folder.
Graham Bell
Sorry for the delay in replying Mike will check it out as you suggest
G.B.
Graham Bell
I am struggling to locate the error log in FD 7,any ideas on where I should be looking?
Regards-
G.B.
Sorry Graham, I don't use FD these days and don't have it installed.
It's 10 years since I was last involved with FD.
There should be a Help file available from within FD.
I am certian there's a log file.  Check the menu in FD, is there a tab called "Log Files"?
Graham Bell
Thank you Mike ,will keep looking!!
Regards-
G.B.
Graham
Try disabling and re-enabling each lookup, one-by-one.  You should find the culprit.
Graham Bell
Graham Bell
Just an update on this hiccup as Mike suggested I have restricted the look up sites to just one and all seems to have settled down and I can rely on the alert feature with confidence!.Thank you Mike for your valued input.
Regards-
G.B.
