November 28, 2026, 12:10:48 AM
Planeplotter output
Started by Saudistu, March 30, 2019, 01:15:54 PM
Saudistu
Currently I feed Flightaware from Planeplotter. I know that this will be stopped soon. I have a question about the Planeplotter output. Can this output be used to feed a Raspberry Pi in order to then Feed FR24 ? I have an SBS-3 which feeds Basestation on a Windows PC. This in turn feeds Planeplotter and the FR24 Software (which is also being discontinued). I don't need Basestation. I am only interested to use Planeplotter and also feed FR24 for the Business sub. Is this possible with just an SBS-3, Windows PC and a Raspberry Pi ? Can the SBS-3 feed Planeplotter on Windows AND another feed to the Raspberry Pi ? I have zero experience with Linux based systems, but if it is possible I will commit to buy a Raspberry :) Thanks for any help !
#1
Hi Saudistu,
This post might help you.
https://radarspotting.com/forum/index.php/topic,9678.msg41158.html#msg41158
Basically you can stick ModeSdeco between the SBS and BaseStation and fork off a Beast output to the Pi.
If you want to I think you could feed PP with the Beast output from ModeSdeco and leave BaseStation out of the equation.
UPDATE:
I'm using an RTL USB device, so you might need to use ModeSmixer to connect to the SBS and then output  feed(s) in the format(s) you want.
I've found my FlightAware USB dongle performs at least as well as my SBS-1eR (I think better, but haven't done a proper analasys!).
I've got a very limited knowledge of Linux but I managed to set up the Pi using the image for piaware and I've since added the FR24feed software.
The instructions for both could be improved I think but I managed to get it working.
I set up the Pi with a keyboead and monitor attached but once it was configured I configured it for SSH access
https://www.raspberrypi.org/documentation/remote-access/ssh/ and use Putty https://www.putty.org/ to access it from my Windows PC.
Keef.
Saudistu
#2
Hi Keef. Thanks for the info. I will start to trawl through the ModeSdeco and ModeSmixer info. I think I used one of them before when I was trying to get Basestation to work with a DVB-T stick. I don't really use Basestation anymore as I now find Planeplotter more useful. So, I am assuming that ModeSmixer and ModeSdeco sit on the Windows PC and relays info out on a Port that can be picked up on the Raspberry Pi to be used for the FR24 Feed ? Hope that makes sense.
UPDATE: I just bought a RPi 3B+ kit so I will see what I can do with it when I am back home in a week or so !
#3
I think you summed it up nicely.
ModeSdeco and mixer are console application you start from a batch file.
I'm not using ModeSmixer but I think the batch file you would need would look something like:
@echo off
cmd /c modesmixer2.exe --inConnect 192.168.0.170:10001 --outServer beast:xxxxx
PAUSE
exit
That is assuming your SBS is on IP address 192.168.0.170 and is using the default port 10001.
The beast port can be any unused port of your choice, but use number 1024 or higher, below that are 'well known' ports that may well be in use by other applications.
If you want ModeSmxer to output a feed so you can still run BaseStation you could add, for example:
--outServer sbs10001:10002
You would then need to tell BaseStation to connect to the port 10002 feed created by ModeSmixer.
Keef.
Saudistu
Thanks once again. I will give it a go when my shift in LEJ has finished :)
Saudistu
Ok a quick update. Got home from LEJ and set up the RPi which was easier than I thought using Putty. Added PiAware and FR24 feed software. I had bought a FlightAware stick even though I had a MicroAdsb stick and a couple of DVB-T sticks lying around. Everything runs perfect. I bought on Amazon for 11 Euro an SMA WiFi antenna splitter (infact it came with two). I split my external antenna to the FlightAware stick and my SBS-3 and the loss is insignificant. Still getting plots over 200 miles away, and for the price who can argue ! Glad I did it now.
You did well with the splitter.  I've always found the cheap ones were no use, with one output stronger than the other.
I look out for used Mini Circuit ones on eBay.
