November 28, 2026, 12:22:43 AM
PlanePlotter 6.4.8.4 Released
Started by Triple7, May 18, 2019, 10:14:05 PM
From Bev,
http://www.coaa.co.uk/planeplotter6_4_8_4.exe
[Generating specific outline files]
I have added a feature to PlanePlotter to make this easy.  The version on the web site now includes :
Options...Chart...Outlines...Generate a new outline Upper case "G" is the short cut.
This option allows you to create a new .OUT file that can be used in PlanePlotter, by clicking on the vertices of any area currently displayed on the screen.
To use the tool, first open a calibrated map or a satellite view covering the area of the new .OUT file. Select Options..Chart..Outline..Generate new outline (or type upper case "G").
A pop up dialog will ask for the comment field to be included in the .OUT file, the TYPE code which defines the colour that will be used for the outline, and the name of the .OUT file that you want to create. The comment should be included in curly braces; the TYPE code should match the default format; the file name should end with ".OUT". When you have completed the dialog, press OK and then begin to click on the vertices of the new polygon that you want to create. It might be the outline of a runway that is currently displayed in a satellite image or the outline of a restricted area currently displayed on the chart. After the first click, PlanePlotter will join the dots to display the outline that you have created as it grows. The preview will display in red although after it is complete, it will display in the colour defined by the TYPE code.
When you have completed the series of clicks to create the desired new outline, click Options..Chart..Outline..Generate new outline (or type upper case "G") once again and the system will ask you if you want to "close" the polygon. If the polygon is open ended, the start and end being in different places, answer "No". If it is an outline of, for example, an airfield, click "Yes" and PlanePlotter will make sure that the final point of the polygon coincides with the first point on which you clicked to make a closed loop.
You can now enable the display of the new .OUT file by selecting Options..Chart..Outline..Select Outline files to plot, and then repainting an outline. This tool can only create one single continuous path, which may be a closed loop, in one .OUT file. If you want to combine several such patterns into a single .OUT file, you can simply create the .OUT files one at a time using this procedure and then concatenate all the files into an appropriately named .OUT file.
I did a quick calibration of the SkyVector chart for the area of Old Warden and then applied the new tool to click round the circle-with-a- flattened side around Old Warden and it yielded the following which seems to match the chart symbol.  Save it as a .OUT file in the PP chart file directory and enable it in Options..Chart..Outline..Select.
Bev
COAA
-------made with PP version 6.4.8.4----
{Old Warden Zone}
$TYPE=2
+52.03867+-0.42426
+52.04274+-0.43036
+52.04680+-0.43573
+52.05494+-0.44183
+52.06150+-0.44479
+52.07146+-0.44793
+52.08074+-0.44941
+52.09161+-0.44904
+52.09908+-0.44812
+52.10633+-0.44571
+52.11200+-0.44275
+52.11744+-0.43980
+52.12356+-0.43462
+52.12833+-0.42870
+52.13174+-0.42185
+52.13356+-0.41538
+52.13403+-0.40780
+52.13269+-0.39947
+52.12976+-0.39207
+52.12592+-0.38634
+52.11959+-0.37968
+52.11236+-0.37506
+52.10648+-0.37228
+52.09742+-0.36969
+52.08905+-0.36858
+52.08112+-0.36821
+52.07274+-0.36951
+52.06368+-0.37210
+52.05552+-0.37617
+52.04781+-0.38116
+52.03867+-0.42426
-1
Downloaded this today and installed.
Thought I would check status. After running GS/MU test PP tells me "This installation is ready for Ground Station validation" and to post an email on the PP user group requesting validation.
I thought I already was a GS for several years. I am receiving MLAT data on my installation so what gives?
I logged on to PP Yahoo group for first time in ages and I see the message numbers dropped from 400 in Sep 2018 to single digit figures in Nov 2018 and none since Feb 2019.
Anyone have the background story to what is going on?
Ah, I see PP goup has moved to https://groups.io/g/planeplotter
I must have missed the announcement!
