May 17, 2024, 08:08:53 AM
SBS 1 not responding
Started by chimney1, September 28, 2019, 11:44:38 PM
Falcon200EX
I have 192.168.1.170
Port 10001
Thanks.  It's possible the EM has failed but you originally mentioned a Windows update occurred and it stopped connecting via Ethernet afterwards.
This could be a total red herring and I've only seen one EM failure in nearly 15 years.  Do you know anyone locally who has an ethernet enabled SBS that you could test with your setup and vice-versa?
Falcon200EX
Unfortunately I don't know anyone who has an ethernet enabled SBS they all rely on other radar software.
My SBS stopped working after the windows update so I assumed it was down to this as nothing else has changed with respect to my setup.
Don't know what avenue to go down now as we've tried everything apart from getting a second hand SBS box and see if that does the trick assuming that the EM module as failed.
If you want to send me the EM I can test it for you?  I'll cover the return postage.
I have a couple of SBS-1 here, both with an EM installed.  One EM works, the other has failed.
I can quickly check out your EM for you.
Falcon200EX
Yes please, would it be easy to post the SBS as opposed to just the EM as I'm not sure how to remove it from the SBS.
Thanks Mike
I've sent you a personal message.
Falcon200EX
I'll get the SBS in the post to you tomorrow.
Many thanks for your help it's much appreciated.
