May 21, 2024, 06:39:35 PM
Mode-S Beast Flightaware RockPi-S 512 MB
Started by Liveatc, February 05, 2023, 12:49:46 PM
Liveatc
Hello , I have a Mode-S Beast from the receiver
Flightaware , I bought a RockPi-S 512 MB and want to connect it to the receiver and run the beast-splitter . How do I get it hooked up and running? If you can go step by step, I'm not very good with linux commands.
Do you only have the receiver from the FlightAware FlightFeeder?  Or the whole device?
My kit is packed away as I rebuild my office.  Does the receiver have a USB port?
Liveatc
Connected, coming from the receiver via USB0
You need to install a ModeS message decoder on the RPi.  Something like PiAware.
Liveatc
Found it on the website https://discussions.flightaware.com/t/new-install-of-piaware-3-cant-communicate-with-beast/37369/23#h-64-bit-beast-splitter-beast-splitter_71_arm64deb-uploaded-to-github-1
I installed it and had no problems installing it.   When I run journalctl -u beast-splitter -n 20 I do not see the settings.  Is there a step by step instruction on how to configure these DIP .
The --listen, --connect, and --force options take a "settings string" which is a list of letters that indicates which settings to turn on or off. These settings mostly correspond to DIP switch settings that can be set on the Beast. Generally, uppercase means "turn on" and lowercase means "turn off". If a setting is omitted, this is a "don't care" setting where beast-splitter will not override that setting either way.
