May 04, 2026, 09:47:24 AM
SBS1-er power supply
Started by flyoverfred, November 02, 2020, 04:13:01 PM
flyoverfred
Hi guys
I'm going to attempt the over Ethernet set up with my box, i'm not 100% sure which power supply I require and the last thing I want to do is blow my box up ! I'm based in the US, can anyone point me in the right direction to the requirements please ?
Kinetic once advised for SBS-1eR:
I always recommend 12v DC Centre positive 300ma
flyoverfred
Quote from: Anmer on November 02, 2020, 05:19:07 PM
KMinetic once advised for SBS-1eR:
Thanks Anmer, I guess I would just stick some sort of usb adapter on the end of one then as a search doesn't seem to being any up with a USB connection as standard so to speak
Isn't the connector a Mini-B?
Maybe a suitable adapter for the power supply?
Sorry, the SBS-1eR had dual power options:
1. USB
2. DC supply with 5.5mm jack, 2.5mm pin
flyoverfred
Quote from: Anmer on November 02, 2020, 07:45:40 PM
looks like it, can't find one with that adapter on by default - thanks for the help
flyoverfred
Quote from: Anmer on November 02, 2020, 08:20:27 PM
1. USB
Oh, that changes things - I'll find something from that - thanks  :)
Check the jack socket and pin size.
I have only ever used the USB-B connector on my SBS-1e.
Something like this:
https://www.amazon.com/UGREEN-Charging-Controller-Players-Receiver/dp/B00P0GI68M/ref=sr_1_3?dchild=1&keywords=usb-b&qid=1605398333&s=electronics&sr=1-3
with a USB phone/tablet charger.
Safer than finding the correct PSU.
@ flyoverfred
Are you planning to use the power supply to feed the downstream PoE connection?
flyoverfred
Quote from: Anmer on November 15, 2020, 08:20:50 AM
@ flyoverfred
Hey Anmer, I'm not 100% sure what that means but my plan is to mount my aerial in the attic and run the sbs1-er over ethernet - so i need to power the box with a plug rather than the usb
flyoverfred
Quote from: IanH on November 15, 2020, 12:01:26 AM
yeah that's how i've always done it but I can't do that going forward as per the post above
