November 29, 2026, 02:56:04 AM
Silhouttes in Operator Logo column
Started by Magic440, May 29, 2021, 12:39:42 PM
Magic440
Just wondering, if there is a easier way than manually editing the ICAO code,to get the silhouttes to show,where the operator logo is missing.
I'm updating the database by using ADU software.
David.
If you want to see a type silhouette in the BaseStation aircraft list, the type has to populate the Operator Flag Code field in the Basestation.sqb.
The aircraft list isn't able to display a logo and a silhouette, just one or the other.
You could use SQL to "batch" populate empty Operator Flag Code fields with the ICAO Type Code, assuming that field is already populated for the aircraft record(s).
Magic440
That's exactly what I'm after Mike. Unfortunately,i'm not familiar with SQL,and wouldn't know where to start re a command. Lol
David.
I think this should do it but please make a copy of the sqb file for backup before running the SQL
update aircraft set operatorflagcode = icaotypecode where operatorflagcode is null
Magic440
I have SQLite downloaded,and backed up the SQB file.
No idea what to do now.lol
David.
Quote from: Magic440 on May 29, 2021, 04:01:27 PM
In SQLIte, open the relevant database:
File->Open Database
Then select the SQL tab and paste the command followed by "Execute SQL"
Magic440
