November 26, 2026, 10:22:28 PM
Basestation Problem.
Started by BLACKHAWK101, June 29, 2021, 01:57:22 PM
BLACKHAWK101
Good afternoon, I seem to be having a problem with the basestation program the details below keep poping up but Basestation continues to work but it is very anoying. No changes have been made to BS for a very long time. Does anybody have any ideas.
Many thanks and regards
Steve Coulson
App: BaseStation
Version: 1.2.4.185
Occurred : 10:53:03.886 2021/06/29
Error : EInvalidOperation - Canvas does not allow drawing
Last Command : INSERT INTO Flights(SessionID, AircraftID, StartTime, Callsign) VALUES (257, 54363, '2021-06-29 10:53:02.855', '')
Last Aircraft : 896356
System Status : 27721728 | 0 | 27721728 | 23242848 | 2323316 | 3.7.11 | 815015989248
Previous : O-WriteToDebugMemo | I-WriteToDebugMemo | O-MainSecondTimerTimer | O-GeneralConnectionTimer | I-GeneralConnectionTimer | O-RadioMenuCheckingTimer | I-RadioMenuCheckingTimer | O-VersionInfoCheckingTimer | I-VersionInfoCheckingTimer | O-StatusBarTimer | I-StatusBarTimer | O-ProvisionalAircraftListTimer | I-ProvisionalAircraftListTimer | O-AircraftListTimer | I-AircraftListTimer | O-AircraftListGridTimer | O-AircraftListGrid.UpdateValues | G-AircraftListTimer-Updating | O-HandleOnSelectedAircraftChanged | I-HandleOnSelectedAircraftChanged | G-AircraftListTimer-Sorting | I-AircraftListGrid.UpdateValues | I-AircraftListGridTimer | O-RedrawTimer | I-RedrawTimer | O-DisplayTrackingTimer | I-DisplayTrackingTimer | O-AircraftTimer | O-DispatchDelayedMessages | I-DispatchDelayedMessages
Quote from: BLACKHAWK101 on June 29, 2021, 01:57:22 PM
App: BaseStation
Version: 1.2.4.185
This may not be relevant, but from where did you get BaseStation 1.2.4.185?
The last known release, that I know of, was 1.2.4.184.  I helped another member the other day who had 185 and only resolved his issue by making a fesh install of 184.
Your issue may be memory related.  How many files do you have in the OperatorFlags folder?
I now have to go out for a few hours so may not be able to reply until later today.
Mike i have found this site where they say 185 is available.
https://en.freedownloadmanager.org/Windows-PC/BaseStation-FREE.html
beware this is not a valid kinetic programme
Quote from: mhm on June 29, 2021, 04:39:05 PM
Thanks Mike.
Just wary of this version.  Who knows what's in it!
BLACKHAWK101
Hi Mike,
I have removed the Logo file and the problem has gone for the moment. I will remove 185 later and install 184 and see what happens. Thanks for the point in the right direction.
Steve Coulson.
Quote from: BLACKHAWK101 on June 29, 2021, 05:52:46 PM
Did you find a rogue file using BMPChk?
BLACKHAWK101
Hi Mike,
not yet checked, but will let you know what i find.
Steve Coulson
BLACKHAWK101
Hi Mike,
Did BMP check, and i have 9010 logos and 5 had warnings. I have removed the 5 and now have 9005 all clear.
Would you say that 9005 logos is to many ?.
Steve Coulson
Quote from: BLACKHAWK101 on June 30, 2021, 07:36:52 PM
Really depends on your available memory.  If it works OK now with the rogue file removed, see how it goes.
I only have 2,183 as I'm pretty dull when it comes to logos.  ???
BLACKHAWK101
Hi Mike,
So i  have got the origional desk which came with the SBS 3 and it loads and comes up as 185 any thoughts.
Steve Coulson
Quote from: BLACKHAWK101 on June 30, 2021, 08:16:19 PM
Thanks Steve.
I didn't get a disk when I got the SBS-3 so haven't seen one.  I was part of the Kinetic test team and never saw a version 185 andf it was never made available for download.  So we possibly missed out.
BLACKHAWK101
Hi Mike,
So final details for the moment, BS Version 1.2.4.185, Released 26/02/2014.
Added data output in NMEA format for AIA messeages on ethernet TCP port 30007, allowing access to AIS data from the SDR puck.
Fixed a problem where the internal radio toolbar was being configured instead of the SDR toolbar.
Hope this helps and many thanks for all of the help you have given.
Steve Coulson
Thanks Steve.
Was that from a release note on the CD?
BLACKHAWK101
BLACKHAWK101
Hi Mike/all,
So i have been runing ok for a few days and have done some work on the countries DAT file. The SBS program will not load with the following showing up,
If i remove the countries DAT file the program loads.
Any one have any ideas, this set up has been runing for years with no problems and then all of a sudden loads of problems.
Many thanks for any help,
Steve Coulson
