November 25, 2026, 09:31:32 PM
sbs 3 AIS question
Started by skippyinspace, September 26, 2012, 08:07:55 PM
skippyinspace
Just got my SBS 3 and have got ACARS working so started on AIS
I dont have an ethernet connection, just staight USB,
So what settings do I need to put in and where.
Since AIS is ship related, you may not get too many replies.  ;)
To make use of any AIS data (are you near the sea?) you need something like ShipPlotter to present the received data.
This post on the Kinetic forum may help:
http://www.kinetic.co.uk/forums/viewtopic.php?f=43&t=15267&sid=461aa9ebf246389861bd8beab3a534a3
skippyinspace
I am by the sea and had been using marine gadget and shipplotter
The more I read the more confused I get
Mature68
Try this out
Setup AIS on Ethernet.
BASESTATION.
Setup Basestation first if you have updated firmware and software you will now
have 2 tuner channels and 6 radio channels.
Setup AIS in tuner B with freqs 161.000 Squelch off and put 161.9750 in SDR 6
and set it as FM to tuner B.
Next goto start basestation and goto Hardware Setting then Network Settings
and put your IP in address and port 10001, Next goto Settings Non Volatile Memory Settings
put your IP address in and port 10001.
Next step Basestation Settings Data Scource chance to Use Network then save the settings
in Non Volatile Memory/Store Radio Settings.
Shipplotter.
Open Shipplotter and click on I/P Settings TCP/IP input tick Client put 30007 in Remote port
and your IP in Remote IP slot.
Put the Red End of lead in your usb port to your sbs3 box.
skippyinspace
thanks for the help, think my problem at the momment is that I dont have ethernet set up!
