November 15, 2026, 10:06:18 PM
Range Plot plugin missing
Started by Lincolnshire Poacher, February 01, 2026, 10:50:46 AM
Help. I am new to VRS, I have it connect3d to my Raspberry pi. its showing I am picking up plenty of aircraft, I have the Silhouettes and flags showing ok.
I now want the range plots, I couldn't find it anywhere, then I checked the plugins and found I have none.
Can anyone guide me to finding and installing the required plugin please?
Quote from: Lincolnshire Poacher on February 01, 2026, 10:50:46 AMI now want the range plots,
Can you describe "range plots"?  Do mean a bearing and distance to a selected aircreft from your home location or range rings, such as these shown in BaseStation?
Or the range you're receiving, such as the attached?
Quote from: Anmer on February 01, 2026, 12:33:03 PM
This is what I mean, I believe you can get different colours depending on the range.
I'm not a regulat VRS user.  But looking at the VRS documentation, range plots can be configured using Map options.  However, I can't see an option to enable or disable them.
I've configured my VRS to show Range Plots (as per the documentation) but they don't display for me!
Quote from: Anmer on February 01, 2026, 01:21:58 PMThanks.
its in VRS setup. I had to  add the location in two different places, range is now in the list.
