September 21, 2026, 08:36:57 PM
Anyone help me with a question?
Started by LX-LGN, June 17, 2013, 07:30:14 PM
LX-LGN
Can anyone help me with this?
I have an old 'Hauppauge WinTV Nova-T USB 2.0 External PCTV Tuner Card' that I no longer have software for, also it will not install or work with my current laptop which is Windows 7.
I have adsbscope already.
Can this be converted into a ADS-B receiver?
If so how can I do it?
Thanks in advaance.
kered
#1
It all depends on the tuner chip that is inside and its capabilities to tune to the frequency. You might have to take off the casing to find out which chip it has, then do a search on say google with the chipset number and ads-b and some results should come up, even if its just to say it won't work. The main ones usable are the R820T and E4000
Some others can be seen here http://www.lll.lu/~edward/edward/adsb/tunerdb/tunerdb.html there may be morechips usable
LX-LGN
Thanks, I'm now home from work and had a look.
It appears to have a label of ENV57H12D5 on the casing around the box where the ariel socket attached and the words www.pedeu-panasonic.de on it.
I tried a google but it's not come up with anything.
Why not give this a try?
It will either work or not and the try is free:
http://www.flightradar24.com/dvbt-stick
LX-LGN
I won't have it on all the time so it would be criminal of me to take one and not supply data regularly.
I am saving for a GNS 5890.
So i was thinking that my old WinTV Nova T USB 2 would be a stopgap.
THanks
Sorry, what I meant was try using the one you have with RTL1090.exe.
kered
I found a few places that say the wintv nova will not work as sdr so little chance for adsb,
One of these will http://www.ebay.co.uk/itm/DVB-T-USB-TV-FM-DAB-Radio-Tuner-Receiver-Stick-Realtek-RTL2832U-R820T-MCX-/290798519228?pt=UK_Computing_Video_Capture_TV_Tuner_Cards&hash=item43b4f143bc and for the price won't break the bank.
I have a few, though i haven't compared it to the GNS 5890 but compared to the Beast i'm pretty impressed for the price. It will work with plane ploter and almost all the other adsb programs like basestation, globeS etc.
LX-LGN
Thanks guys for the help the 1090 didn't work but I'll hang on until I get the GNS.
I'd buy a DVB-T USB stick and save some money.
I found the DVB-T performed as well if not better than the GNS.
kered
Quote from: Anmer on June 19, 2013, 07:02:41 PM
A lot of money in that case, the cheapest i've seen the gs5890 is 99 quid(no pound sign on my keyboard) for the difference you could get some good cable and an antenna for the DVB-T and make it even better
LX-LGN
Thanks guys.
Looks like for £10-15 I can get a Realtek RTL2832U R820T MCX, get good coverage and start off easy. Thing is I will have it on my laptop so mostly it'll be either when I am at work (if I can put my laptop out of site of the boss), when I am at home (sitting near the window) or when I visit LCY, LGW or LHR for a few hours.
What would you suggest for cable and Antenna?  I may need a long cable when in the office.
Money is limited is the only other issue.
The antenna location is important.  It needs to "see" as much sky as possible.  Hiding it from the boss may be a challenge.
One option that I have yet to try is using a USB extension cable between the PC and DVB-T USB stick.  It should work and gives you the option to place the antenna in a better location, away from the PC.
LX-LGN
Maplin do a a 5M extension lead http://www.maplin.co.uk/usb-2.0-active-5m-extension-lead-97272
Suitable for speeds up to 480Mbps << Would this be fast enough for the DVT-B and ADS-Bscope?
mezoo
I dont know about the Maplin cable or DVB-T, but my 10m USB cable is handling up to 4 ADSB receivers at the same time - two dongles, a transponder mouse and a GNS - all with plenty of traffic.
