September 04, 2026, 03:08:57 AM
abcd567
Quote from: sergsero on August 08, 2020, 06:36:25 AM
Hello,
Please use this version of modesmixer2 if your operating system is Ubuntu 20.04 64 bit: https://drive.google.com/file/d/1BH7zPxzk7qTMhhGOD6KPHMnM7qRf4_Dc/view?usp=sharing
Best regards,
Thank you Sergsero!
abcd@ubuntu20-vm:~$ wget -O modesmixer2_ubuntu_20.04_x86_64_20200714.tgz "https://drive.google.com/uc?export=download&id=1BH7zPxzk7qTMhhGOD6KPHMnM7qRf4_Dc"
abcd@ubuntu20-vm:~$ sudo tar xvzf modesmixer2_ubuntu_20.04_x86_64_20200714.tgz
abcd@ubuntu20-vm:~$ ./modesmixer2 --inConnect localhost:30005 --location 43.5:-79.6 --web 8787
2020-08-08 23:05:59.452  INFO     ModeSMixer2 v.20200714
2020-08-08 23:05:59.452  INFO     The Magnetic Declination was calculated
2020-08-08 23:05:59.454  INFO     inConnect(localhost:30005) connecting 127.0.0.1:30005
2020-08-08 23:05:59.455  INFO     inConnect(localhost:30005) connected
2020-08-08 23:05:59.993  INFO     inConnect(localhost:30005) BEAST data stream detected
2020-08-08 23:06:19.239  INFO     The Coverage Area was determined
2020-08-08 23:06:19.239  INFO     The Magnetic Declination was calculated
abcd567
Automated Installation of ModeSMixer2 On Ubuntu 20.04 amd64 & Kali Linux 2020.2 amd64
(modesmixer2 is installed with Systemd Controls)
Uses following Linux binary for both the above noted distros (Ubuntu20 & Kali2020)
copy-paste following bash script and press the Enter key.
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/mm2/master/install-mm2-ubuntu20.sh)"
After script finishes, it displays following message
INSTALLATION COMPLETED
PLEASE DO FOLLOWING:
(1) If installed on RPi, in your browser, go to web interface at http://ip-of-pi:8787.
(2) If installed on Ubuntu20, in browser of Ubuntu go to web interface at http://localhost:8787 or http://127.0.0.1:8787
(3) Open file mm2.sh for editing by following command:
sudo nano /usr/share/mm2/mm2.conf
Add following line:
--location xx.xxxx:yy.yyyy
(Replace xx.xxxx and yy.yyyy by your
actual latitude and longitude)
After entering location, Save (Ctrl+o) and Close (Ctrl+x) file md2.conf
then restart mm2 by following command:
sudo systemctl restart mm2
To see status: sudo systemctl status mm2
To restart:    sudo systemctl restart mm2
To stop:       sudo systemctl stop mm2
CONFIGURATION
The configuration file can be edited by following command;
Default contents of config file
Default setting are for a decoder like dump1090-mutability or dump1090-fa running on the Computer on which ModeSmixer has been installed.
This can be changed by editing config file
You can add extra arguments, one per line starting with --
--inConnectId 127.0.0.1:30005:ADSB
--inConnectId 127.0.0.1:30105:MLAT
--web 8787
To see all config parameters
modesmixer2 --help
UNINSTALL
To completely remove configuration and all files, give following 4 commands:
sudo systemctl disable mm2
sudo rm /lib/systemd/system/mm2.service
sudo rm -rf /usr/share/mm2
sudo rm /usr/bin/modesmixer2
Any chance of a Debian Buster version of ModeSMixer2?
That is my preferred distro: Ubuntu has too many extras.
Hello IanH,
I will see what differences there are in the library versions and try to compile it for debian quickly.
/sergsero
abcd567
I have Debian 10.5 (Buster) amd64.
As mm2 binary is not available for it, I tried to use Ubuntu18 binary "modesmixer2_Ubuntu_18.04_x86_64_20190223.tgz"
Failed due to missing "libssl.so.1.0.0"
$ INSTALL_FOLDER=/usr/share/mm2
$ sudo mkdir ${INSTALL_FOLDER}
$ sudo wget -O ${INSTALL_FOLDER}/modesmixer2_Ubuntu_18.04_x86_64_20190223.tgz "https://drive.google.com/uc?export=download&id=1QzUqYTt-Bf-m817-i3W_RvodB019kxC5"
$ sudo tar xvzf ${INSTALL_FOLDER}/modesmixer2_Ubuntu_18.04_x86_64_20190223.tgz -C ${INSTALL_FOLDER}
$ sudo ln -s ${INSTALL_FOLDER}/modesmixer2 /usr/bin/modesmixer2
$ modesmixer2 --inConnect 127.0.0.1:30005 --web 8787 --location 43.5:-79.6
modesmixer2: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
Debian package search showed "libssl1.0.0" is NOT available in Debian Buster and Stretch resources, but is available in Debian Jessie resources.
Downloaded Jessie version and tried to install, but failed:
$ sudo wget -O ${INSTALL_FOLDER}/libssl1.0.0_1.0.1t-1+deb8u12_amd64.deb "http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u12_amd64.deb"
$ sudo dpkg -i ${INSTALL_FOLDER}/libssl1.0.0_1.0.1t-1+deb8u12_amd64.deb
Selecting previously unselected package libssl1.0.0:amd64.
dpkg: regarding .../libssl1.0.0_1.0.1t-1+deb8u12_amd64.deb containing libssl1.0.0:amd64, pre-dependency problem:
libssl1.0.0 pre-depends on multiarch-support
  multiarch-support is not installed.
dpkg: error processing archive /usr/share/mm2/libssl1.0.0_1.0.1t-1+deb8u12_amd64.deb (--install):
pre-dependency problem - not installing libssl1.0.0:amd64
Errors were encountered while processing:
Installed package "multiarch-support" and could install the libssl1.0.0 from Jessie resources.
$ sudo apt install multiarch-support
Now tested, Bingo! it is working
2020-08-17 11:57:13.890  INFO     ModeSMixer2 v.20190216
2020-08-17 11:57:13.890  INFO     Magnetic declination calculated
2020-08-17 11:57:13.893  INFO     inConnect(127.0.0.1:30005) connecting 127.0.0.1:30005
2020-08-17 11:57:13.893  INFO     inConnect(127.0.0.1:30005) connected
2020-08-17 11:57:14.430  INFO     inConnect(127.0.0.1:30005) BEAST data stream detected
2020-08-17 11:57:26.697  INFO     Coverage area was determined
2020-08-17 11:57:26.697  INFO     Magnetic declination calculated
Hello,
Intel x86-64 CPU
$ cat /etc/debian_version
10.5
The Debian 10 Buster 64 bit version of modesmixer2: https://drive.google.com/file/d/1gKtk2rP_IgOK53ZJQX2MAERCkoqvbAD6/view?usp=sharing
$ cat /etc/centos-release
CentOS Linux release 8.2.2004 (Core)
The CentOS 8 64 bit version of modesmixer2: https://drive.google.com/file/d/1ghZkpFjAIOWU84JZRgaZckkDIjIkKTyb/view?usp=sharing
% freebsd-version
12.1-RELEASE-p8
The FreeBSD 12 64 bit version of modesmixer2: https://drive.google.com/file/d/132F8njLcEFgacAOIa-w7taPZXiMgGjGW/view?usp=sharing
Best regards,
abcd567
Thank you Sergsero for latest binaries.
On my Debian 10.5:
(1) Directly downloaded the .tgz file from Google Drive by following command:
$ sudo wget -O modesmixer2_debian_10_x86_64_20200714.tgz "https://drive.google.com/uc?export=download&id=1gKtk2rP_IgOK53ZJQX2MAERCkoqvbAD6"
(2) Uncompressed downloaded .tgz file by following command:
$ sudo tar xvzf modesmixer2_debian_10_x86_64_20200714.tgz
(3) Tested:
$ ./modesmixer2 --inConnect 127.0.0.1:30005 --web 8787 --location 43.5:-79.6
2020-08-22 15:39:49.670  INFO     ModeSMixer2 v.20200714
2020-08-22 15:39:49.670  INFO     The Magnetic Declination was calculated
2020-08-22 15:39:49.670  INFO     no distances.json provided
2020-08-22 15:39:49.670  ERROR    unable to dump polar distances to file
2020-08-22 15:39:49.671  INFO     inConnect(127.0.0.1:30005) connecting 127.0.0.1:30005
2020-08-22 15:39:49.671  INFO     inConnect(127.0.0.1:30005) connected
2020-08-22 15:39:50.268  INFO     inConnect(127.0.0.1:30005) BEAST data stream detected
2020-08-22 15:40:10.548  INFO     The Coverage Area was determined
2020-08-22 15:40:10.548  INFO     The Magnetic Declination was calculated
abcd567
Automated Installation of ModeSMixer2 on Debian 10.5 (x86_64):
Copy-paste following single-line command in terminal and press Enter key. The script will do everything for you, and when installation is completed, will give brief guide.
(The single-line command is very long. Scroll right to see & copy it in full.)
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/mm2/master/install-mm2-debian10.sh)"
To edit Config file:  sudo nano /usr/share/mm2/mm2.conf
After editing & saving config file, restart modesmixer2:  sudo systemctl restart mm2
Default contents of config file:
--web 8787
You can add parameters such as --location, --outConnect, etc, one parameter per line
Folder containing all files:  /usr/share/mm2
Help:  modesmixer2 --help
For detailed instructions visit this web page:
https://github.com/abcd567a/mm2/blob/master/README.md
w4lron
Hi All
I'm using RPi3 + Kinetic Puck 1090.My settings are as follows
--inSerial /dev/ttyUSB1:3000000:none
--outServer beast:30005
--add-points 38.44:27.01
--location 38.44:27.01
--web 8787
but I have been getting a connection error for 2 days...
2020-08-31 00:08:39.056  ERROR    inSerial(/dev/ttyUSB1:3000000) error open No such file or directory
2020-08-31 00:08:39.056  INFO     inSerial(/dev/ttyUSB1:3000000) Reconnect in 10 seconds
2020-08-31 00:08:49.057  ERROR    inSerial(/dev/ttyUSB1:3000000) error open No such file or directory
2020-08-31 00:08:49.057  INFO     inSerial(/dev/ttyUSB1:3000000) Reconnect in 10 seconds
2020-08-31 00:08:59.057  ERROR    inSerial(/dev/ttyUSB1:3000000) error open No such file or directory
2020-08-31 00:08:59.057  INFO     inSerial(/dev/ttyUSB1:3000000) Reconnect in 10 seconds
I can't find the reason. Can you help me?
Before;
there was no problem  :(
Using SBS-1, Fr24Box, Puck1090
Sorry, yes, it is my fault that the processor architecture is not explicitly specified. All these builds above are made for Intel x86-64 architecture.
Thank you for the Debian 10 version. As abcd567 says Ubunti version does not run (despite trying to symlink libraries) so I have been using the 2015  ::) Debian version of MM2
abcd567
Ian H
I have successfully installed following latest version without need for any workaround for libraries:
On Ubuntu 20 amd64 & Kali Linux 2020 amd64
On Debian 10.5 amd64
radioman1511
Hi greetings Why can´t see no registration code. I use dump1090-fa and Debian10.5.
radioman1511
I have it,the problem was the BaseStation.sql. Thanks for all.greetings radioman1511
