November 28, 2026, 12:18:50 AM
Hello,
New test version of ModeSMixer2 20150220.
+ fixed some bugs
+ added interpretation of airport codes on route. To see, place cursor in rotation on the ICAO airport codes
+ added second table on Google map that displays list of aircraft. To ON/OFF, you need to press on button in right side of header
+ added decoding and displays IC (Interrogator code): II (Interrogator identifier) and SI (Surveillance identifier)
blkno1
I have now tried the latest version with Raspberry Pi Plus and I agree.
I can't get the --db or  --silhouettes options to work.
** --db option does work once I have a good BaseStation.sqb file!
** --silhouettes option works once I get the path correct!
All the other bits of the web interface seem to be working.
So the question is - what silhouette files are you using? I copied IanK's files into the required folder - see link on right of web page.
APO1972
Hello to all,
Me too i have problem feeding data to BaseStation from a USB RTL dongle via ModeSDeco2 (.bat file    @echo off
cmd /c modesdeco2.exe --gain 49.6 --sbs10001 10001
PAUSE
exit)
See the attachment snapshot , pressed debug button at BaseStation menu.
blkno1
I have the *.zip of silhouettes (*.bmp files) from Iank's site in a dir named /silos.  I've double checked the paths.
./modesdeco2_2015_02_20 --gain 49.6 --freq-correction 53 --silhouettes ~/modesdeco/silos --web 8080 --localtime
I've tried both ~/modesdeco/silos    and /home/pi/modesdeco/silos paths.
-blkno1
Make sure the *.BMP files are in /home/pi/modesdeco/silos path.
Do an "ls" in that path since unzipping IanK's file creates another directory!  I had to move the BMP files.
blkno1
Can confirm that all the *.BMP files are in fact in the /home/pi/modesdeco2/silos dir path.
snippet of dir listing
pi@ironhide ~/modesdeco/silos $
Hello APO1972,
Can you confirm that you use the last version 1.2.4.184 of Basestation.exe?
APO1972
Ahhh...nope...i'm still using v161...because my device is old SBS-1 MKI(5v) with an SBS1-EM(Ethernet module) Firmware 306 and the last version of BaseStation can run well MapModeS Server(MMS Server)-- if you know(sharing datas from different SBS Kinetic devices)-- was 161.
When to the past test 184 didn't worked the ability of MMS.
Nevermind i'll try 184 in an another folder and tell you.
APO1972
OK that was the problem...today i run it on v184 and worked perfectly!!!
Thanks a lot
APO1972
Hi Anmer!
How are you?
I run the mmccepbep of Boris...http://mode-s.66ghz.com/ , not the MMS Client ,modified as you know the Basestation.ini such as below:
[DataInterface]
DataSourceType=1
SocketIntfIPAddress=192.168.1.170
SocketIntfPort=10001
IsConfigured=1
MapModeSSetToUse=1  <-------------------then must appear on menu bar the MapModeS tab
MapModeSIntfIPAddress=192.168.1.2
MapModeSIntfPort=20070
But unfortunately in v184 do nothing...it's not working at all
Sorry, I thought it was SBS1 Client, my mistake.
I am fine.  How are you?
APO1972
I'm fine!
Recently i bought 2 dongles and begun tests...i want to find out their capabilities(sensitivity,size of data can recieve per day,maximum range) in comparison with my older SBS-1 MKI...
I purchased some antenna adaptors for the time being and waiting for them , you know from ...mcx to UHF female , BNC Female , because i   must do the tests with the same antenna...and antenna position of course...
That's all
Hi sergsero,
I've run the latest 'test' version for 24 hours with no problems on a Win 8.1 64 bit machine.
I was pulling in about 40-50 contacts most of the day, obviously fewer at night, and all worked well throughout.
I was set up to feed Basestation as well as having the web interface enabled with silhouettes, pictures and sqb paths defined.
I like the web interface you have created, it's very well done.
Thanks for the effort you've put in to developing the software.
APO1972
I'm very happy! after my tests with modesdeco2 v20150220 feeding data from USB Donlge to Basestation.
Is very stable and in <<real time>> , i mean the targets are in same position on the same time as with the SBS-1 device feeding Basestation.
Also non-ADSB aircrafts shows on the Basestation aircraft list.
My .bat file is the below :
@echo off
cmd /c modesdeco2.exe --device-index 0 --gain 49.6 --freq-correction 64 --rbs --sbs10001 10001 --location 40.64:22.93
PAUSE
exit
Have you got any better than this?
