November 28, 2026, 01:14:55 AM
nurmiin
Quote from: Rockwell on June 13, 2015, 11:28:41 AM
./modesdeco 2 --gain 48.0 --rbs --location 49.572:7.601 --web 8000 --metric --db BaseStaion.sqb --silhouettes /modesdeco/Outlines
Folder Silouettes with silouettes files is in folder modesdeco.
You can try bare name of the folder like this:
--silhouettes Outlines
Best Regards
Hi Rockwell,
QuoteFolder Silouettes with silouettes files is in folder modesdeco
If this is true, then why are you in the line to run program, use --silhouettes /modesdeco/Outlines?
And if the directory is not in a root, but in your user directory, default /home/pi, I can say that missing the "~":  --silhouettes ~/modesdeco/Silhouettes.
Or specify the full path to the folder: --silhouettes /home/pi/modesdeco/Silhouettes.
Rockwell
sonicgoose
Seeing an issue with the latest modesdeco2 (20150603) and modesmixer2 (20150612) for Windows. When loading the web map in my browser (Safari 8.0.6, OS X 10.10.3 and Google Chrome 43.0.2357.124, Win 7 Ultimate 32-bit), all aircraft are being plotted in the top-left corner and the Google map does not load. See attachment for a screenshot. I'm seeing this on three separate computers. This is a sporadic issue: sometimes it loads properly and sometimes it doesn't.
Rockwell
Quote from: sonicgoose on June 13, 2015, 04:32:04 PM
Same is happening when I open browser on my pi2.  Charts, Stats, Flights and Log just working fine but map same problem as Sonicgoose.
map5623
Hello Sergsero
Would it be possible in ModeSDeco2 to filter aircraft above/below a certain flight level or altitude.
thanks
spotter.ssol
Sorry for this dumb question, but what is meant by the letters "A" and "S" precisely?
dschaper
Quote from: spotter.ssol on June 14, 2015, 01:21:39 AM
Mode A/C and Mode S
Hi sonicgoose,
You need to do bypass your cache in browser.
To speed things up and conserve communications bandwidth, browsers attempt to keep local copies of pages, images, and other content you've visited, so that it need not be downloaded again later. Occasionally this caching scheme goes awry (e.g. the browser insists on showing out-of-date content) making it necessary to bypass the cache, thus forcing your browser to re-download a web page's complete, up-to-date content.
Bypassing your cache means forcing your web browser to re-download a web page from scratch, which can often solve website display glitches. It is also required after installing user scripts. Bypassing your cache is simple, safe, and causes no permanent changes.
When you are on the page "Map":
In most Windows and Linux browsers: Hold down Ctrl and press F5.
In Apple Safari: Hold down ⇧ Shift and click the Reload toolbar button.
Hi spotter.ssol,
These letters signify the type of transponder, which is used on this aircraft.
For uniformity of characters with VRS, where they also used, the letter means ADS-B (selection criteria is coordinates and DF17 messages)
and the letter corresponds to Mode S.
sonicgoose
Quote from: sergsero on June 14, 2015, 04:17:50 AM
Hi sonicgoose,
I have tried bypassing the cache, and have even gone so far as to empty the cache completely, but I'm still experiencing the issue. This is an issue that did not appear in previous versions of both modesdeco2 and modesmixer2.
Rob
spotter.ssol
Quote from: sergsero on June 14, 2015, 04:40:52 AM
Hi spotter.ssol,
Thanks sergsero! Is there any plans to upgrade the raspberry pi version of modesdeco2?
mlino
Quote from: sergsero on June 12, 2015, 01:48:25 PM
ModeSMixer2 v.20150612
+ added option --web-auth <arg> Enable web auth username:password (default: off)
+ added option --filter-ic Enable Interrogator Code filter (default: off)
+ added option --metric Enable metric system of distance measurement
+ added ability to select rows for aircraft's label on the map
+ added ability to display METAR data (with decoding them by pushing on the string) for one airport
+ table on Google map is draggable. Move it by clicking on it with the mouse and dragging it anywhere within the viewport
+ added option --location <arg> for one point with lat:lon
+ added option --disable-web-log suppresses console messages on WEB page Log (default: on)
QuoteIf you see on the page Map that all aircraft are being plotted in the top-left corner and the Google map does not load, then you need to do bypass your cache in browser.
Good Job Sergsero!
Thank you so much for the improvements on modesmixer.
Marcio
Hi sonicgoose,
In #366 message of the thread is corrected version 20150616.
+ fixed bug in CPR decoder's filter
+ used the release version v=3.20 of Google Maps API
I hope that the changes will solve the  problem:
Quoteall aircraft are being plotted in the top-left corner and the Google map does not load
Unfortunately it's possible that  you'll have to clear your browser's cache (via menu Control-Shift-Del), which was previously used with version 20150612.
I will be grateful to you for testing and feedback.
grezz
sergsero,
I have a problem with these new versions of modesmixer2 on my RPI2.
Using version 20150323 I used to be able to share the output from my Beast with flightaware and other sites with this call:
/home/pi/mm2/modesmixer2 --inSerial /dev/ttyUSB0:3000000:hardware --web 8081 --outServer beast:30005 --outServer sbs10001:10002 --outServer sbs30006:30003 --outServer fatsv:10001 --log-noconsole
With the new versions and the exact same call, I can see modesmixer2 working fine when I browse its web server page (I love the improvements there by the way!) but data is not being received by piaware. The log shows connections to ports 30005 and 10001 but piaware does not receive anything. I have had to revert to version 20150323 which works as it always did.
grezz
