November 29, 2026, 02:10:53 AM
sonicgoose
Quote from: sergsero on June 17, 2015, 03:12:38 AM
Hi sonicgoose,
In #366 message of the thread is corrected version 20150616.
+ fixed bug in CPR decoder's filter
+ used the release version v=3.20 of Google Maps API
I hope that the changes will solve the  problem:
Quoteall aircraft are being plotted in the top-left corner and the Google map does not load
Unfortunately it's possible that  you'll have to clear your browser's cache (via menu Control-Shift-Del), which was previously used with version 20150612.
I will be grateful to you for testing and feedback.
Hi, sergsero
I've installed 20150616 from message #366. I'm still experiencing the same map issue in both Safari and Chrome in OS X. Chrome in Windows appears to be ok, though.
Hi sonicgoose,
Unfortunately, I can't reproduce the issue on my Mac in Safari 8 and Google map is displayed correctly.
Hi grezz,
There is indeed a issue in working with piaware soft. If you need this feature, use the previous version 20150323.
grezz
Thanks for the info sergsero. Is the piaware issue something that will be worked on in future versions?
grezz
larsras
Any idea why i often see the same airplane twice, often once as Mode-S and once as ADS-B, but here it is 2 x Mode-S? See screenshot attached.
I believe it started with the latest ModesDeco2 update.
Hi larsras,
As far as I can see on the screenshot, all clones apply only to Mode S aircraft. An error occurs in the decoding of one bit. All three aircraft with ADS-B (4CA53F, 4CA73B and 45AB41) are present in a single instance.
Try adding the option --filter-ic and please let me know, would that to affect the issue.
larsras
I added the filter, but it didn't seem to help. The previous screenshot was also an unusual example with only Mode-S, but i have attached new screenshoots, as i normally see it. Both are after i enabled this filter.
Rockwell
This strange behaviour happen also with older version.
Tried as suggested filter but this doesn't solve the doubles.
Also zoom behaviour is strange; to big or to small.
Hi larsras and Rockwell,
Think I know the reason of this issue and I will try to fix it in future versions.
/sergsero
Hi grezz,
I think I fixed the bug in program with output piaware format. Just download again the archive, inside it there is a changed version of an executable file. Please, test it.
/sergsero
grezz
sergsero,
It works so far! Thanks for the quick fix - love your work.
grezz
G0HEU
grezz
G0HEU,
The fix is for modesmixer2 to play nice with piaware, which runs on the RPI, so I doubt it.
grezz
mlino
Hi Sergsero,
Is there any chance to include the feature suggested into msg #355 in a future release?
Marcio
VE7LFL
First posting....I am using an older version of Modesmixer2, and now would like to update with the latest....how would I do the update, do I remove the older version, or will the newer version over write the older....Modesmixer2 runs very well with my remote RPI and Beast...
Doug
