November 15, 2026, 10:04:13 PM
ADL not updating BS.
Started by Smudger98, September 01, 2013, 11:46:48 AM
Smudger98
Ran ADLite this morning and the update feature seems not working on mine..?
Tried GASPOP and that works fine, Ian tells me the full version works fine so is it just mine or all of ADL?
I have attached a couple of screen shots to show the missing buttons, reloaded the PC, Reloaded ADL several times and no joy, any ideas please gents..
corsa
Hi Smudger
I've just had a look at my ADL and have got the same problem with  "missing buttons"
I don't know how long this has been happening as i have been busy this last couple days
so I have not used it
Smudger98
Sent an Email to Gary @ GAS, responded within minutes.. top draw service, awaiting further details and updates..
Smudger98
From Gary..
Re: ADLite Query If I May..
New postby cessna24v » Sun Sep 01, 2013 11:29 am
Thx for letting us know, Smudger.
We are trying to find the cause of the problem and have replicated it here.
Nothing we are aware of has changed so we are trying to find out what has happened.
The program seems to work in all aspects except Autopop which is turned OFF and it should always default to ON in the initial Beta version which hasn't changed in 2 years.
I'll post here when we find the problem.
Gary
corsa
Thanks for posting their reply, It will be interesting to find what has caused this problem...
Smudger98
Quote from: corsa on September 01, 2013, 12:43:25 PM
Makes a change.. normally its something that  I`ve done...  :P
Smudger98
#6
ADLite is now back working.. close and reload- if you get the RED AP button, toggle it GREEN and press start..
Any other problems.. tell someone else..  ;D
Smudger98
The reply from Gary at GAS...
We believe we have resolved this issue and you need to do the following to restore ADL correctly...
Close ADL if you still have it open and/or running.
Reload ADL and the A-P button should be back.
If it IS and it is red just toggle it to green.
OR
If it IS and is green, just leave it alone.
Click Start and normal service should be restored.
The fault was a webservice DB entry.
The absolute cause hasn't yet been confirmed but was probably due to work we have been doing for the first proper release
and probably happened very late yesterday evening.
If you haven't started ADL since then, you shouldn't have the problem and there is no need to follow the above instructions.
Many thanks to Smudger for reporting the problem and then confirming the resolution.
Gary
cessna24v
corsa
Hi Smudger
Thanks for all the info, I have followed the instructions and all is fine and thanks to Garry
for a quick response to the problem...
Smudger98
Still having ADLite issues.. It now wont display unknowns or populated in the lower box.. which in turn wont update Basestation ??
No black line for the unknowns as per the attached picture.
NB.. Gary aware.
Smudger.
Smudger98
Looking better.. now getting the unknowns listed..  ;D
Smudger98
Looking Good..
