May 27, 2026, 07:04:22 PM
PP and Planefinder.
Started by charliebrown, May 02, 2014, 11:21:02 AM
charliebrown
Hi Guys,
I am trying to share my data from PP with Prinkfroot.com for Planefinder.
I type in the appropriate boxes in the PP Sharing Setup window, then when I then reopen the Sharing setup window, the text in the boxes has been deleted.
I have an SBS1er with Windows 8.1 64 bit version and the 1090 Kinetic Puck.
Any suggestions what might be causing the boxes to delete ?
Charlie
satcom
There is nothing to "type in "
You just tick the box according to who you want to secondary share with
PlaneFinder
FR24
Flightaware
even Radarbox24
Couldn't be easier
I suspect you are using a very old version of PP.
One thing to note....the refresh cycle for  secondary sharing defaults to 15 seconds...I suggest you change that to 60 seconds otherwise you are just loading your CPU.
charliebrown
Hi sitcom,
Silly me.  :-[
I am using latest PP version.
However, I was following the instructions on the Pinkfroot.com website for sharing and I thought I had to fill in sharing details as well as ticking the box (see below).
Charlie
satcom
No problem
I'll try and get the Pinkfroot instructions updated
charliebrown
Hi Satcom
I have contacted Mark at Pinkfroot and he will update the web page on PP sharing.
Thanks for your very prompt replies and help.
Charlie
