September 20, 2026, 05:43:46 PM
Active Display SD22 error
Started by quedgeley2002, April 07, 2012, 11:14:51 AM
quedgeley2002
I have started to receive this error;-
SD22 Flights for new Session cannot be found. Please (re)start Basestation Parameter is not valid
This seems to occur when Basestation, Planeplotter and Active Display are left running for more than a 24 hour period since last shutdown.  To clear the error (as it indicates I need to shut down everything however the error seems to return quickly. A full PC reboot is the only way to solve the problem.
I am running Windows 7 (32 bit), Basestation 1.2.3.159, Planeplotter 6.2.5.7, Active Display 1.32.4.0a
Any help would be appreciated.
Is that using the full (fee paid) version of Active Display?
Rather than doing a full PC reboot, have you checked Task Manager to see if the process is still running and then close it via Task Manager?
Have you seen this thread on Kinetic forum?
http://www.kinetic-avionics.co.uk/forums/viewtopic.php?f=40&t=14629&start=0&hilit=SD22
quedgeley2002
Hi Anmer
Thank you for the prompt reply.
Yes, I am using the full fee paid version of the application. I have force closed the application via Task Manager as suggested and have started it again and it is now catching up from 0714 this morning when it stopped.
Unfortunately I can't see the post in the Kinetic Forum as I am still awaiting for approval to be able to view and post in that area of their site.
quedgeley2002
Following on from my earlier post the 'catch up' has failed at 1137 with the same SD22 error.
Unfortunately without access to the Kinetic Forum I can't follow up on the post in there.
Thanks so far
Keith
Sorry Keith, I didn't realise Kinetic had blocked Guests viewing posts on it's forum.
Six new members were approved in March so Kinetic hasn't totally stopped approving applications.
Can I suggest you send an email to:
support@kinetic.co.uk
....as per this post:
http://radarspotting.com/forum/index.php/topic,326.msg2088.html#msg2088
quedgeley2002
Okay, thanks for that e-mail link, I'll follow up with them to get my access to that forum resolved.
Thank you for your patience!
Keith
Gary from GAS is very good at responding to posts on the Kinetic forum.
