April 25, 2026, 07:47:51 AM
FR24 feed software
Started by KeithH, December 22, 2015, 07:31:20 AM
Roadrunner
I use SBS3 via ethernet and it also stopped 2 days ago. I did nothing other than send an email to FR24 support. This morning it appears to be working correctly again. Glad I was too busy to do anything else over the last couple of days so didn't waste a lot of time. However, thanks to those that got listened to.
Merry Christmas and a Happy New Year.
They should have tested update before uploading live.
Quote from: mhm on December 25, 2015, 07:40:38 AM
Too busy counting its money.
eddm_muc
New Feeder Version is out for Windows and PI.
Win Version is working fine for me
KeithH
Quote from: eddm_muc on February 04, 2016, 07:59:41 AM
Hi, If you have it working how did you answer the "setup" questions please?
The first time it is run there are several questions that are not discussed in the PDF manual.  I have tried answering "No" to each but just get a repeating message that it cannot connect to the hardware.  I seem to remember that this was the same the last time they released new software and the software wants sole access to the (in my case) Puck.  Not good if, like me, you want to run basestation at the same time.
Keith
KeithH
Quote from: KeithH on February 05, 2016, 12:54:45 PM
Keith
ah, I think I have it sorted.  The first question asks for hardware type.  Need to select the last option SBSx NOT SBS1 or SBS3.
Oldfella
Also had success with feeding SBS3 to FR24 using these  settings in the FR24 config file -
receiver="basestation"
fr24key="xxxxxxxxxxxxxxxx"
host="localhost:30006"
bs="no"
raw="no"
logmode="1"
mlat="no"
mlat-without-gps="no"
Also the latest FR24 software -
http://feed.flightradar24.com/windows/fr24feed_win32_1.0.16-11.zip
I'm a happy chappie
Oldfella
Ian K
Anybody else getting a Network error/ could not connect message ? currently getting Red/Yellow triangles.
KeithH
Quote from: Ian K on May 04, 2016, 06:12:18 PM
Everything working well here!
Which feeder version are you using Ian?
#55
I'm seeing exactly the same as you Ian. It started earlier today, after my ISP - Plusnet had a wobble.
I think the version I am using is 1.0.16-11.
I am seeing things like this in the command feeder window:
2016-05-04 18:43:06 | [feed][n]connecting
2016-05-04 18:43:06 | [stats][i]Stats thread started
2016-05-04 18:43:06 | [feed][n]connected via UDP (fd 812)
2016-05-04 18:43:06 | [feed][n]working
2016-05-04 18:43:16 | MSGS-OK: 0
2016-05-04 18:43:16 | MSGS-ER: 0
2016-05-04 18:43:16 | [reader][e][0]Could not connect to 192.168.1.90
2016-05-04 18:43:21 | [reader][i][0]Connecting to SBS1 receiver on 192.168.1.90:10001
2016-05-04 18:43:36 | [feed][n]ping 1
2016-05-04 18:43:42 | MSGS-OK: 0
2016-05-04 18:43:42 | MSGS-ER: 0
2016-05-04 18:43:42 | [reader][e][0]Could not connect to 192.168.1.90
2016-05-04 18:43:47 | [reader][i][0]Connecting to SBS1 receiver on 192.168.1.90:10001
192.168.1.90 is my PC running ModeSMixer as the feed from SBS to my LAN. However trying 192.168.1.170 (the SBS's IP address) I get the same:
2016-05-04 18:44:54 | [reader][i][0]Initializing reader
2016-05-04 18:44:54 | [reader][i][0]Connecting to SBS1 receiver on 192.168.1.170:10001
2016-05-04 18:44:55 | MSGS-OK: 0
2016-05-04 18:44:55 | MSGS-ER: 0
2016-05-04 18:44:55 | [reader][e][0]Could not connect to 192.168.1.170
2016-05-04 18:45:00 | [reader][i][0]Connecting to SBS1 receiver on 192.168.1.170:10001
2016-05-04 18:45:01 | MSGS-OK: 0
2016-05-04 18:45:01 | MSGS-ER: 0
2016-05-04 18:45:01 | [reader][e][0]Could not connect to 192.168.1.170
2016-05-04 18:45:04 | [time][i]Time synchronized correctly, offset +0.0035 seconds
Might be my ISP or something else  :-\
KeithH
Quote from: Triple7 on May 04, 2016, 06:52:59 PM
192.168.1.90 is my PC running ModeSMixer as the feed from SBS to my LAN. However trying 192.169.1.170 (the SBS's IP address) I get the same:
I'm running the same version here and everything has seemed good all day.  I have just stopped and restarted the uploader and it still seems to be running well.  Strange!   Firewall issue??
Ian K
How do you find out which version is in use ?
I just restarted PC but still have the same message
KeithH
Quote from: Ian K on May 04, 2016, 07:05:26 PM
When you start the uploader the second line lists the version number.
HTH
#59
Right click on the fr24feed.exe and look at the details tab - which revealed I am actually using 1.0.15.7
No firewall issues all FR24 programs / apps have full access.
EDIT: just upgraded to 1.0.16-11 with the same result - won't connect
